1965 Nova Dash trim help!
Having some trouble designing the corner of this piece that I'm working on.  See the pictures.  I've figured out out to slice off the corner on the back first by creating a plane through three points and then making it a body and removing it.  Then my latest try at it is create the bend in a plane turn the plane at the proper angle and intersect extrude the piece through that plane and that gave me what I was looking for but then when I went to add the extruded frame on the front it will not follow the curve in the top right corner.  Help!  Pictures to show what I'm trying for.  Thanks Mark
20180926_085632.jpg20180926_085623.jpg20180926_085606.jpg20180926_085556.jpg20180926_085526.jpg20180926_085511.jpg
SwApNiLbAd
you just need to use form command in fusion from that command you will get what you need.Untitled.png
SwApNiLbAd
Hi @Anonymous sorry last time mistakenly write command.
you have to use create to make your 3D model.
thankyou
TheCADWhisperer
File>Export and then Attach your *.f3d attempt here.
chrisplyler
I haven't worried about matching your shape exactly, or put in the time to get tangencies and/or smooth curvatures, but you might be able to use a Sweep with a Guide Rail to control the stretching of a profile.
Thanks for the suggestion! I'm currently working on getting up to speed on printing this set out and then I'll circle back around and tackle this one.  There's a left and right corner like this to do.  - mark
Ok taking another crack at it.  Here's where I'm at so far.  I feel like I'm missing a tool in my bag that will help me with this.  Maybe someone can point me in the right direction to which tool I need to bone up on and use.
Mark
