Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
What do exactly getPrincipalMomentsOfInertia() gives?
3 REPLIES 3
479 Views, 3 Replies
In short,
1. getPrincipalMomentsOfInertia() didn't work as I expected. So what exactly it returns?
2. I have a model with "moments of inertia atcenter of mass" with ixy, izy, ixz != 0 (or saying far away). Is it a normal case? I thought it should be a diagonalized matrix.
I was working on grabbing diagonalize moments of inertia from the models, saying I want the diagonalized form of the MOI, getting ixx, iyy, izz with all other elements (ixy, iyz, ixz) equals to 0
The Properties UI will display MOI_world and MOI_CoM (Center of Mass), and I can export these two information by using getXYZMomentsOfInertia(), and calculating MOI_CoM from getXYZMomentsOfInertia and physicalProperties.centerOfMass().
However, sometimes the CoM is magically not have ixy, iyz, ixz equals to 0 when my model is complex. And the value not looks like caused by numerical error and it is relatively not small enough to close to 0.
And then I try to explore getPrincipalMomentsOfInertia(). At first from the description I think it will give the ixx, iyy, izz I want but it does not. And I am also not sure what exactly these values are.
# Get the moments of inertia about the principal axes. Unit for returned values is kg/cm^2.
(retVal,i1,i2,i3) = physicalProperties.getPrincipalMomentsOfInertia()
Here is an example with a Ball, Ring and Cylinder. Theoratically the Ball should have the diagonalize MOI with same value as shown in List of moments of Inertia Wiki
MOI_CoM displayed in UI looks reasonable, but the value of getPrincipalMomentsOfInertia()  (In my document, it is the "MOI_principal", where I add another three 0.0 b.c. I thought it was the ixx,iyy,izz) is strange and I cannot tell what they are.
MoI about CoM with ixy, ixz, iyz != 0. (Sorry I cannot show you my model but only the Properties screenshot)
It looks like a physical problem. Will I always get a diagonalized MoI about center of mass? I know MOI is diagnolized when it align with principal axes, but are they the same for the concept of "MoI at CoM"?
Notes:
dict_of_links["center_of_mass"]: Direct output from physicalProperties.centerOfMass
dict_of_links["inertia"] : The moment of inertia about center of mass. It is diplayed in UI but have no direct method to get this from API. I calculated it from the MOI about world frame and CoM.
dict_of_links["MOI_principal"]: Direct output from physicalProperties.getPrincipalMomentsOfInertia() and just add another three 0.0.
dict_of_links["radius_of_gyration"]: Direct output from physicalProperties.getRadiusOfGyration().
Ref
1. Get Physical Properties API Sample API Sample
2. PhysicalProperties.getPrincipalMomentsOfInertia Method
In short,
Notes:
Ref
3 REPLIES 3
kandennti
kandennti
Hi yl1242.
I do not understand the contents, but here physicalProperties_var.getXYZMomentsOfInertia ()
Some people point out that the documentation for is incorrect.
(However, it is Japanese)
http://syuntoku14.hatenablog.com/entry/2018/09/24/085723
(returnValue, xx, yy, zz, xy, yz, xz) = physicalProperties_var.getXYZMomentsOfInertia()
not
(returnValue, xx, yy, zz, xy, xz, yz) = physicalProperties_var.getXYZMomentsOfInertia()
Seems to be correct.
There may be these effects.
Hi yl1242.
not
in reply to: kandennti
Thank you for pointing that out 🙂
I am exactly working with syuntoku14's code. (https://github.com/syuntoku14/fusion2urdf)
I sent a pull request to his repo and thought it was a bug but looks like it's not after reading the post.
After testing, I think the issue you pointed out has already been fixed by Fusion.
So there should be some other staff happening here
kandennti
kandennti
