Is it possible to create a button in a menu that when clicked will take the user to a specified web address?
Solved by Jorge_Jaramillo. Go to Solution.
I believe you have two options:
1) Open browser, external to Fusion 360 with the following code:
import webbrowser
webbrowser.open('http://example.com')
2) Use a palette dialog window inside Fusion 360 which in turn loads your target URL.
Here you have a link to Palettes Object in Fusion's help guide:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7E998C17-1AC8-47F4-B922-8F4481857FEA
Hope this could help.
Jorge Jaramillo
