Using Min and max parameter
Hello! Is there any way to restrict a distance to have 5 mm as a lower limit? I want it to relate to the distance d3 if it is over 5 mm. Have tried to read about min / max parameters but do not really understand how they are used.
JeromeBriot
Try this formula for the d3 dimension: max(parameter, 5mm)
jamie.emmart.NZ
Update to JeromeBriot's solution. Fusion would not accept the "," for me. Had to separate parts with ";", ie max(parameter; 5mm)
