Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Round up angles script
8 REPLIES 8
Message 1 of 9
nubrandao
189 Views, 8 Replies
Hi, is possible to create an API script with a pop up message with a angle round?
Or could an excel sheet work?
Here's the situation.
In our company, he have 2 machines, that A e B body, have restricted angles
For example example, B body rotates 1 degree, example B: 85/86/87...
A body rotation is every 3 degrees
Example A: A: 3/6/9/12../87
So, to calc for those machines, I have to round up the angle.
If I use align to view will go for example: turn 75.45678
Flip 34.56785
I have to round this numbers.
It would be perfect a script that create a named view renamed with the angle round to 0.0 degrees, then when align, I input the round numbers.
Would like to hear your suggestions
8 REPLIES 8
Message 2 of 9
kandennti
in reply to: nubrandao
Hi @nubrandao -San.
It's just words, so I don't have a clear picture of what I'm looking for, but it seems like it could be done with Joint's functionality without having to create a script.
Message 3 of 9
nubrandao
inside manufacture
Message 4 of 9
kandennti
@nubrandao -San.
A sample script was created to round up the “Turn” and “Tilt” of the selected operation.
# Fusion360API Python script
import traceback
import adsk
import adsk.core as core
import adsk.cam as cam
import math
_app: core.Application = None
_ui: core.UserInterface = None
_handlers = []
CMD_INFO = {
    "id": "kantoku_RoundUpAngles",
    "name": "RoundUp Angles",
    "tooltip": "RoundUp Angles"
_SelIpt: core.SelectionCommandInput = None
_infoIpt: core.TextBoxCommandInput = None
_camObj: cam.CAM = None
class MyCommandCreatedHandler(core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandCreatedEventArgs):
        try:
            app: core.Application = core.Application.get()
            global _camObj
            _camObj= app.activeProduct
            global _handlers
            cmd: core.Command = core.Command.cast(args.command)
            inputs: core.CommandInputs = cmd.commandInputs
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            _handlers.append(onExecute)
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
            onPreSelect = MyPreSelectHandler()
            cmd.preSelect.add(onPreSelect)
            _handlers.append(onPreSelect)
            global _SelIpt
            _SelIpt = inputs.addSelectionInput(
                "_SelOpeId",
                "Operation",
                "Select Operation"
            global _infoIpt
            _infoIpt = inputs.addTextBoxCommandInput(
                "_infoIptId",
                2,
                True
        except:
            _ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class MyPreSelectHandler(core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.SelectionEventArgs):
        ope: cam.Operation = cam.Operation.cast(args.selection.entity)
        if not ope:
            args.isSelectable = False
            return
        prm: cam.CAMParameter = ope.parameters.itemByName("overrideToolView")
        if not prm.value.value:
            return
class MyInputChangedHandler(core.InputChangedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.InputChangedEventArgs):
        global _SelIpt, _infoIpt
        if _SelIpt.selectionCount < 1:
            _infoIpt.text = "-"
            return
        ope: cam.Operation = _SelIpt.selection(0).entity
        prmTurn: cam.CAMParameter = ope.parameters.itemByName("view_turn_from_recipe")
        prmTilt: cam.CAMParameter = ope.parameters.itemByName("view_tilt_from_recipe")
        valueTurn = prmTurn.value.value
        valueTilt = prmTilt.value.value
        roundTurn = roundUp(valueTurn, 0.1)
        roundTilt = roundUp(valueTilt, 0.1)
        _infoIpt.text = "\n".join(
                f"Turn: {valueTurn} -> {roundTurn}",
                f"Tilt: {valueTilt} -> {roundTilt}",
class MyExecuteHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args: core.CommandEventArgs):
        global _SelIpt
        prmTurn.value.value = float(roundTurn)
        prmTilt.value.value = float(roundTilt)
        global _camObj
        _camObj.generateToolpath(ope)
class MyCommandDestroyHandler(core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        adsk.terminate()
def roundUp(v, roundUpUnit) -> str:
    roundValue = math.ceil(v / roundUpUnit) * roundUpUnit
    global _camObj
    unitsMgr = _camObj.unitsManager
    return unitsMgr.formatValue(roundValue, "", 1)
def run(context):
    try:
        global _app, _ui
        _app = core.Application.get()
        _ui = _app.userInterface
        cmdDef: core.CommandDefinition = _ui.commandDefinitions.itemById(
            CMD_INFO["id"]
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition(
                CMD_INFO["id"],
                CMD_INFO["name"],
                CMD_INFO["tooltip"]
        global _handlers
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
Message 5 of 9
nubrandao
I will try thank very much
Message 6 of 9
nubrandao
can you modify to to have no decimal value? for example:      turn 87.3423 >  turn 87
flip 43.2544 >  flip 43
Message 7 of 9
nubrandao
solved, i chanegd the values , perfect
Message 8 of 9
nubrandao
@kandennti hey mate, that works. But I face a problem, I thought that turn and tilt were the same output angles from the machine.
For example, I turn 85degree and tilt 30 degree, the machine output is A 251.456 and B 243.8663
Those numbers are just a example.
In this case , I need the reversed angles
For example, in NC simulation  I have to find the round angle output,and the adjust turn and tilt to match the A and B body angles
Message 9 of 9
kandennti
@nubrandao -San.
I am sorry, but I do not know the formula to obtain the A and B axes from Turn and Filp.
