Reduce mesh in API
Reduce mesh in API
barbaracc6
Reduce mesh in API
barbaracc6
Hello there!
I am new in using API interface to control Fusion 360 and i am having a little bit of trouble finding the correspondence between Mesh > Modify > Reduce mesh command to Fusion 360 API.
I have a STL file mesh with to many facets. I want to convert it to a body, but, because of the size of it I can't do it. So, I need a little help here trying to reduce the number of facets of the mesh preserving the shape of the model (like the Fusion 360 visual interface provides).
tykapl.breuil
I don't think there is any way to do this through the API.
However, you might be able to use textCommands to do this, as they allow you to simulate what can be done through the UI, see this post.
j.han97
You can execute its command definition (ID: ParaMeshReduceCommand) directly but it is hardly useful unless you manage to figure out how to configure the command inputs with API.
kandennti
Hi @barbaracc6 .
There is no guarantee that it will work in the future, but here is a script that divides the mesh up to the number of faces that can be converted and converts them.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/is-it-possible-to-use-text-command-within-...
kandennti
@barbaracc6 .
I tried.
Process the first MeshBody of the root component.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui: adsk.core.UserInterface = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        if root.meshBodies.count < 1:
            return
        mesh: adsk.fusion.MeshBody = root.meshBodies[0]
        execMeshReduce(
            mesh,
            1000
        ui.messageBox('Done')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def execMeshReduce(
    mesh: adsk.fusion.MeshBody,
    facetsCount: int):
    ui: adsk.core.UserInterface = app.userInterface
    sels: adsk.core.Selections = ui.activeSelections
    sels.clear()
    sels.add(mesh)
    cmds = [
        u'Commands.Start ParaMeshReduceCommand',
        u'Commands.SetDouble infoFacets 1', #dammy
        u'Commands.SetString infoReduceType infoTriCount',
        u'Commands.SetString infoMeshingType infoAdaptiveType',
        u'Commands.SetDouble infoFacets {}'.format(facetsCount),
        u'NuCommands.CommitCmd',
    [app.executeTextCommand(cmd) for cmd in cmds]
barbaracc6
Thank you all for all the help provided. I managed to do what i wanted thanks to you guys!
