trying to install a 2d to 3d script
ppowellpp
ppowellpp
Hi there,
Thank you for any help you can suggest.
I read a story in instructables where a 2d image can be converted to a 3d item with a script, the reference quoted is
"To translate a 2D bitmap image to a 3D surface for CNC milling, we're going to use the Image-2-Surface (updated 03 / 2018) script written by Hans Kellner."
The instructions in instructables says "
To load the script in Fusion, follow these steps:
  1. Start Fusion 360 and then select the ADD-INS > Scripts and Add-Ins... menu item.
  2. The Scripts and Add-Ins dialog will appear and display the My Scripts and Sample Scripts folders.
  3. Select one of the My Scripts folders, then click on the + icon near the top of the dialog.
  4. Locate the Image2Surface.js file in the folder you copied, select it, and click Open. The script should now be installed and ready to be run."
But I cannot find anywhere that is Add ins... Maybe because I have a personal version and it is not full functional? Maybe it has been updated somehow
I have screen shot the image (jpeg) that I'm trying to make 3D with a low profile possibly 4mm high.
Best wishes
Philip
ppowellpp
so I should also mention that I'm MacOS and the instructions at https://help.autodesk.com/view/fusion360/ENU/?guid=SLD-MANAGE-SCRIPTS-ADD-INS
also don't seem to be right, am I doing something wrong?
here is the instructable ii followed:
https://www.instructables.com/3D-CNC-Relief-Sculpture-Fusion-360/
davebYYPCU
Addins are found under the Tools menu in the top line of environments.
Might help.....
JeromeBriot
The TOOLS menu was renamed as UTILITIES.
dmarvelli01
Observer
Observer
i did the file prep nd the fusion image2surface is in the add in folder,but when i go to get it it does not show the Image2surface scipt file ,. any suggestions...
Jorge_Jaramillo
Scripts in js are deprecated in Fusion 360 since 2020.
You have to get someone to convert it to C++ or Python, which are the languages supported currently.
Jorge
dmarvelli01
Observer
Observer
Thanks for your response, will proceed with suggestion.
Regards
Dome
