Python: Using Scale Features at originConstructionPoint moves bodies.
Mehrab.Nasrabadi
Mehrab.Nasrabadi
Hello everyone,
I have a small problem when using the ScaleFeature. I want to iterate through all the bodies and then scale them non-uniformly. The point from which I want to scale should always be the origin of the component of the body. However, I have the problem that the bodies are scaled as I want but as soon as the ScaleFeature is executed the bodies move. I think it is either because of my declaration of the origin or because the scaleFeuture.add(...) does more than it should.🤔 But unfortunately, I'm not getting any smarter from this.
I am very grateful for any help and advice!
I have attached the culprit, maybe someone has the time and inclination to look over it!
Kind regards from Leipzig, Germany😊
import adsk.core
import adsk.fusion
import traceback
def run(context):
    ui = None
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        design: adsk.fusion.Design = app.activeProduct
        design.designType = adsk.fusion.DesignTypes.ParametricDesignType
        rootComp: adsk.fusion.Component = design.rootComponent
        for i in range(0, rootComp.allOccurrences.count):
            occ = rootComp.allOccurrences.item(i)
            # Get the associated component.
            comp = occ.component
            # iterate over bodies
            for j in range(0, comp.bRepBodies.count):
                bodies: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
                bodies.clear()
                body = comp.bRepBodies.item(j)
                body = body.createForAssemblyContext(occ)
                bodies.add(body)
                scalePoint = comp.originConstructionPoint.createForAssemblyContext(occ)
                ui.messageBox(str(scalePoint.geometry.asArray()))
                scaleFactor = adsk.core.ValueInput.createByReal(0.5)
                scaleFeatures = rootComp.features.scaleFeatures
                xScale = adsk.core.ValueInput.createByReal(float(1.55))
                yScale = adsk.core.ValueInput.createByReal(float(1.45))
                zScale = adsk.core.ValueInput.createByReal(float(1.35))
                input = scaleFeatures.createInput(bodies, scalePoint, scaleFactor)
                input.setToNonUniform(xScale, yScale, zScale)
                scaleFeature = scaleFeatures.add(input)
kandennti
Hi @Mehrab.Nasrabadi .
You may not have finalized the position of the component after it has been moved.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/transformation-on-occurrence-getting-reset...
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/quot-move-copy-quot-in-the-context-menu/m-...
How about modifying it like this?
        design.snapshots.add()
Mehrab.Nasrabadi
at first this wasn't a solution for me because i also move the bodies in my script and that doesn't work with the line. but then i just changed my script a bit so that i first move and then scale. and that worked perfectly!
Thank you for your great help and your commitment to the community!
I have another small question, for which it's probably not really worth creating a new post.
It's about the creation of matrices, the setting of their rotation and translation is documented here : https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-GUID-b831d9f4-c231-4b9f-9b4d-658614ecdc79. But why is there no scaling? I mean I could get the individual positions from the transformation matrix and then multiply them by a scaling factor and then set them back to their position in the matrix (which unfortunately didn't work :D). But in my opinion, the methods of a transformation matrix also include scaling. It feels particularly problematic because fusion or many or possibly all CAD programs make a minimal error in the calculation or creation of transformation matrices and as soon as there is a small error in the input, this information is not accepted and the transformation matrix does not work.
But it is not that important because i have now my way to solve that problem!
Thank you and much love for you ❤️
