Python add-in runs OK in a debug session, but NOK at normal runtime
mike46YZU
mike46YZU
I've got a strange problem. I'm working on an add-in to rotate the view though a serial command. In a debug session my test script runs just fine and it does what it is supposed to do. In the "Scripts and Add-Ins" window in fusion I can then stop the script and close fusion normally.
Now when I run that same script normally instead of in a debug session, the script works, but in the "Scripts and Add-Ins" window the Stop button is greyed out. So I cannot stop the script and I cannot close fusion gracefully.
I'm hoping to find some help here, here's my script:
# Assuming you have not changed the general structure of the template no modification is needed in this file.
import adsk.core, adsk.fusion, traceback, math
import time
import threading
import sys
import os
current_dir = os.path.dirname(os.path.abspath(__file__))
packages_path = os.path.join(current_dir, 'packages')
sys.path.append(packages_path)
import serial
sys.path.remove(packages_path)
# globals
app = None
view = None
camera = None
target = None
up = None
dist = None
ui = None
port_name = None
ser = None
thread = None
# Flag to indicate whether the thread should continue running
keep_running = True
data_available = False
angle = 0
def init():
        global app
        app = adsk.core.Application.get()
        global view
        view = app.activeViewport
        global camera
        camera = view.camera
        global target
        target = adsk.core.Point3D.create(0,0,0)
        global up
        up = adsk.core.Vector3D.create(0,0,1)
        global ui
        ui = app.userInterface
        global port_name
        port_name = "COM10"
        global dist
        dist = camera.target.distanceTo(camera.eye)
        global ser
        try:
            # Try to open the specified COM port
            ser = serial.Serial(port=port_name, baudrate=115200, timeout=2)
            ui.messageBox('Port opened successfully!...')
        except:
            ui.messageBox('Cannot open port...')
def run(context):
    global ui
    global angle
    global data_available
    global keep_running
    try:
        init()
        global thread
        thread = threading.Thread(target=read)
        thread.start()
        while keep_running:
            if data_available == True:
                update(angle)
            adsk.doEvents()
    except:
        ui.messageBox('Run Error!')
def update(angle):
    global view
    global camera
    global target
    global up
    global dist
    camera.target = target
    camera.upVector = up
    eye = adsk.core.Point3D.create(dist * math.cos((math.pi*2) * angle/1000), dist * math.sin((math.pi*2) * angle/1000), 10)
    camera.eye = eye
    camera.isSmoothTransition = False
    view.camera = camera
    view.refresh()
def read(): #this method runs in a thread to acquire serial data
    global ser
    global keep_running
    global angle
    while keep_running:
        data = ser.read_until(b'\n')  # Read data until a newline character is encountered
        if data:  # If data is received
            try:
                print(data.decode())
                angle = float(data.decode().strip())  # Convert the ASCII data to a floating-point number
                #print(f"Received floating-point value: {angle}")
                data_available = True
            except ValueError:
                print("Received non-numeric ASCII data")
        adsk.doEvents()
def stop(context):
    global ser
    try:
        global keep_running
        keep_running = False  # Set the flag to stop the thread
        thread.join()         # Wait for the thread to finish gracefully
        ser.close()           # close the serial port
        ui.messageBox('Add-in stopped...')
    except:
        ui.messageBox('stop except')
Jorge_Jaramillo
I believe your problem is a threading issue because the run() function in not finishing to let Fusion 360 do its work to complete the start of the add-in.
In your code you might need to move the while loop to the read() function:
Then you can control all async reading staff within that thread, not inside the Fusion 360's own thread.
That is the reason, I believe, why the close button is grayed out.
Jorge Jaramillo
Software Engineer
mike46YZU
Thanks, that did the trick!
