Problems adding a dropdown menu to my add-in
en9y37
en9y37
Hi dear community!
I'd like to give my add-ins the ability to interact with the user trough text input boxes, dropdowns menus, etc. I thought these would be much easier but I'm finding this quite tricky and it's seeming to me pretty hard to understand.
Here I leave you an example on which I'm working right now. It's a simple dropdown menu in which depending on the selection, several events will be triggered. The point is that nothing at all happens when I run the add-in, the dropdown doesn't appear and the rest of the code is not executed. The code is trimmed to make it easier to understand.
Any idea about what I'm doing wrong? Thanks in advance
import adsk.core, adsk.fusion
import os
from ...lib import fusion360utils as futil
app = adsk.core.Application.get()
ui = app.userInterface
# TODO *** Specify the command identity information. ***
CMD_ID = f'actualizaTodoPostprocesa'
CMD_NAME = 'Actualiza todo y postprocesa'
CMD_Description = 'Actualiza y postprocessa el diseño y sus subensamblajes con los datos de Google Sheets'
# Specify that the command will be promoted to the panel.
IS_PROMOTED = True
# TODO *** Define the location where the command button will be created. ***
# This is done by specifying the workspace, the tab, and the panel, and the
# command it will be inserted beside. Not providing the command to position it
# will insert it at the end.
WORKSPACE_ID = 'FusionSolidEnvironment'
PANEL_ID = 'SolidScriptsAddinsPanel'
COMMAND_BESIDE_ID = 'ScriptsManagerCommand'
# Resource location for command icons, here we assume a sub folder in this directory named "resources".
ICON_FOLDER = os.path.join(os.path.dirname(os.path.abspath(__file__)), 'resources', '')
# Local list of event handlers used to maintain a reference so
# they are not released and garbage collected.
local_handlers = []
# Executed when add-in is run.
def start():
    # Create a command Definition.
    cmd_def = ui.commandDefinitions.addButtonDefinition(CMD_ID, CMD_NAME, CMD_Description, ICON_FOLDER)
    # Define an event handler for the command created event. It will be called when the button is clicked.
    futil.add_handler(cmd_def.commandCreated, command_execute)
    # ******** Add a button into the UI so the user can run the command. ********
    # Get the target workspace the button will be created in.
    workspace = ui.workspaces.itemById(WORKSPACE_ID)
    # Get the panel the button will be created in.
    panel = workspace.toolbarPanels.itemById(PANEL_ID)
    # Create the button command control in the UI after the specified existing command.
    control = panel.controls.addCommand(cmd_def, COMMAND_BESIDE_ID, False)
    # Specify if the command is promoted to the main toolbar.
    control.isPromoted = IS_PROMOTED
# Executed when add-in is stopped.
def stop():
    # Get the various UI elements for this command
    command_control = panel.controls.itemById(CMD_ID)
    command_definition = ui.commandDefinitions.itemById(CMD_ID)
    # Delete the button command control
    if command_control:
        command_control.deleteMe()
    # Delete the command definition
    if command_definition:
        command_definition.deleteMe()
# Function that is called when a user clicks the corresponding button in the UI.
# This defines the contents of the command dialog and connects to the command related events.
def command_created(args: adsk.core.CommandCreatedEventArgs):
    # General logging for debug.
    futil.log(f'{CMD_NAME} Command Created Event')
    # https://help.autodesk.com/view/fusion360/ENU/?contextId=CommandInputs
    inputs = args.command.commandInputs
    # TODO Define the dialog for your command by adding different inputs to the command.
    listaItems = inputs.addDropDownCommandInput('elegirPost','Postprocesador',0).listItems
    listaItems.add("Mucobal",True)
    listaItems.add("Zoroa",False)
    # TODO Connect to the events that are needed by this command.
    futil.add_handler(args.command.execute, command_execute, local_handlers=local_handlers)
    futil.add_handler(args.command.inputChanged, command_input_changed, local_handlers=local_handlers)
    futil.add_handler(args.command.executePreview, command_preview, local_handlers=local_handlers)
    futil.add_handler(args.command.validateInputs, command_validate_input, local_handlers=local_handlers)
    futil.add_handler(args.command.destroy, command_destroy, local_handlers=local_handlers)
# This event handler is called when the user clicks the OK button in the command dialog or
# is immediately called after the created event not command inputs were created for the dialog.
def command_execute(args: adsk.core.CommandEventArgs):
    futil.log(f'{CMD_NAME} Command Execute Event')
   # Get a reference to your command's inputs.
    postUsuario: adsk.core.DropDownCommandInput = inputs.itemById('elegirPost')
    nombrePost = postUsuario.selectedItem.name
    ui.messageBox(nombrePost)
# This event handler is called when the command needs to compute a new preview in the graphics window.
def command_preview(args: adsk.core.CommandEventArgs):
    futil.log(f'{CMD_NAME} Command Preview Event')
# This event handler is called when the user changes anything in the command dialog
# allowing you to modify values of other inputs based on that change.
def command_input_changed(args: adsk.core.InputChangedEventArgs):
    changed_input = args.input
    inputs = args.inputs
    futil.log(f'{CMD_NAME} Input Changed Event fired from a change to {changed_input.id}')
# This event handler is called when the user interacts with any of the inputs in the dialog
# which allows you to verify that all of the inputs are valid and enables the OK button.
def command_validate_input(args: adsk.core.ValidateInputsEventArgs):
    futil.log(f'{CMD_NAME} Validate Input Event')
    True
    # Verify the validity of the input values. This controls if the OK button is enabled or not.
    valueInput = inputs.itemById('value_input')
    if valueInput.value >= 0:
        inputs.areInputsValid = True
    else:
        inputs.areInputsValid = False
# This event handler is called when the command terminates.
def command_destroy(args: adsk.core.CommandEventArgs):
    futil.log(f'{CMD_NAME} Command Destroy Event')
    global local_handlers
    local_handlers = []
Jorge_Jaramillo
Hi @en9y37 ,
I had found some problems in your code:
1) Rename start() by run(context) # this is the entry-fn the API calls to start the addIn
2) Add cmd_def.execute() at the end of run() function  # this is how all commands get to run
3) In the command_validate_input() function the sentence valueInput = inputs.itemById('elegirPost')  gives an error since there is not an command with id 'elegirPost' defined.
At least with the first to fixes, your addIn will run, and you can start debbuging it.
Hope this help.
Jorge
en9y37
Hola Jorge @Jorge_Jaramillo, gracias por la respuesta!
I've been trying with your ideas but my problem still remains. Anyway, I'm quite stubborn and I've been testing several things. The question is that my issues come from other side, I'll try to explain....
In my example I trimmed part of the code to make it more handy, but at same time I hid the real reason of my issues. In my code I call several commands with this function:
app.executeTextCommand(u'Commands.Start ContextUpdateAllFromParentCmd')
Well, everything works fine as long as the command is a "Fusion native" command, as the listed above. The problem comes when I use this function with my own commands or others from external applications:
app.executeTextCommand(u'Commands.Start actualizarGsheet') #My own command
app.executeTextCommand(u'Commands.Start JoinerCadSculptCmd') #Command from JoinerCAD add-in
So, everytime one of these lines is executed, the flow of the executions returns to this point:
In the context of the code, when I debug, I see that when the line 30 is executed, it returns to line 8 directly and starts a non-ending loop, and obviously it crashes.
    # TODO ******************************** Your code here ********************************
    try:
        # NIVEL ROOT_______________________________________________________________________________________
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        dibujo_WS = ui.workspaces.itemById("FusionSolidEnvironment")
        cam_WS = ui.workspaces.itemById("CAMEnvironment")
        dibujo_WS.activate()
        listadoNumero = []
        numeroRoot = design.activeComponent.partNumber
        numero0 = ""
        numeroCNC = numeroRoot + "_"
        listadoNumero.append(numeroCNC)
I hope this time everyone handles more information to focus on which my problems are.
Thanks all!
Jorge_Jaramillo
Hi @en9y37,
Could you check in line 3 what do you get in CommandEventArgs.firingEvent.name? like so:
futil.log(f'{CMD_NAME} Command Execute Event {args.firingEvent.name}')
This will help you identify the command that is being fired.
By the way, do you have a single command execute handler for all yours commands?
What is the command executed handler defined for "ContextUpdateAllFromParentCmd" and "actualizarGsheet" commands?
I believe this is the cause of the endless-loop you is experiencing.
Jorge
en9y37
Hi again @Jorge_Jaramillo.
I guess you mean this...
I think I have just one command execute handler and I didnt define anyone for those commands. But I couldn't say much more, this thing of the handlers overpasses me I hardly understand their purpose. Do you mean this?
Anyway it's quite weird that when I execute with  app.executeTextCommand() a native command everything works fine with no needs of the handlers thing, but not when the command called is from an Add-in.
Thanks again for yyour time.
Jorge_Jaramillo
Please share the source code where you define the "actualizarGsheet" command.
And in the debug you made, also display this property: args.command.parentCommandDefinition.id
en9y37
Here I leave you the whole code of the entry.py file from the command which calls the
import adsk.core, adsk.fusion, traceback, time
import os
IS_PROMOTED = True
local_handlers = []
def start():
    futil.add_handler(cmd_def.commandCreated, command_created)
def stop():
    if command_control:
    try:
        ui.messageBox("Si se muestra esto, no ha entrado en bucle")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
    else:
    local_handlers = []
And the whole code of the entry.py from actualizarGsheet:
import os
CMD_ID = f'actualizarGsheet'
CMD_NAME = 'Actualizar de Google Sheets'
CMD_Description = 'Actualiza el estado del diseño con los datos de Google Sheets, solo en el diseño actual'
IS_PROMOTED = False
local_handlers = []
def start():
    futil.add_handler(cmd_def.commandCreated, command_created) #command_execute ejecuta la secuencia sin pasar por dialogo previo
def stop():
    if command_control:
    ui = None
    try:
        ui.messageBox("Se ha ejecutado actualizar Gsheet")
    except:
        if ui:
    else:
    local_handlers = []
Both codes are reduced to its minimum and they have enough information to replicate the error.
This property: args.command.parentCommandDefinition.id = actualizaTodoPostprocesa, it remains this value along the whole execution.
Other thing I've noticed... when I started to develop my add-ins, since I never used dialogs, instead of removing the dialog samples from the template, I made this change in line 40 in any of my codes:
#Changed command_created to command_execute
I don't know why, but the point is that my codes, (which include tons of "app.executeTextCommand()")  work properly with this simple change, as long I don't need use any dialog, because this way they are passed trough. If I leave the template as it is, the endlees loop comes again.
I think the problem is quite isolated, something related using app.executeTextCommand() to external commands, but I can't figure out which te solution should be.
Muchas gracias por tu tiempo Jorge.
