Post processor and pyton script
CAM_exeger
CAM_exeger
We run the post processing from Fusion 360 by means of a Python script. In this script we set post program properties with a pairs of name and value (see snippet below). When the name of such a property in the Python script matches a user-defined property in the post program, i.e. in the Javascript file (.cps), the program receives the value provided by the Python script. This is good and as expected.
Question: Is it in the Python script possible to read (etc) which user-defined properties in the Post program that are available? In terms of the script snippet below, one would expect something like postInput.<whatever ...> ?
In the Python (.py) script we set post properties, in the case below it is just one property named “testProperty
In the Javascript (.cps) file we define our user-defined properties, in the case below it is just one property named “testProperty”.
// User-defined properties
properties = {
  testProperty: {
       title: "Test of a user defined property",
       description: "Output the machine settings in the header of the code.",
       group: "MyTest",
       type: "string",
       value: "piglet",
       scope: "post",
       enabled: "milling"
  v0 = getProperty("testProperty", "No value provided");
  if (v0) {
    writeln("  getProperty(testProperty)=" + toString(v0));
else {
    writeln("  No property found by getProperty(testProperty)");
pegmK6DND
Observer
Observer
You can run `post.exe --quiet --interrogate  <cps_file.cps>` and parse the resulting JSON string.
See https://cam.autodesk.com/posts/reference/usage.html
