- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Problem
In the new update, I couldn't install modules through pip the way that has usually worked for me:
(this is in Fusion's Python interpreter)
import pip pip.main(['install', numpy])
I just get this now:
Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: module 'pip' has no attribute 'main'
Solution
I found some pip exe's in the Scripts folder that Fusion's python.exe is in.
I was able to run pip this way in Windows PowerShell to install, e.g. numpy.
> .\pip3 install numpy Collecting numpy Downloading https://files.pythonhosted.org/packages/bd/51/7df1a3858ff0465f760b482514f1292836f8be08d84aba411b48dda72fa9/numpy-1.17.2-cp37-cp37m-win_amd64.whl (12.8MB) |████████████████████████████████| 12.8MB 6.4MB/s Installing collected packages: numpy WARNING: The script f2py.exe is installed in 'c:\users\lorraine\appdata\local\autodesk\webdeploy\production\8fc78e02ada35f7bfe8c61944f4c29231b2e06ab\python\Scripts' which is not on PATH. Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. Successfully installed numpy-1.17.2
Check that it is installed and in the right place:
> ./pip3 show numpy Name: numpy Version: 1.17.2 Summary: NumPy is the fundamental package for array computing with Python. Home-page: https://www.numpy.org Author: Travis E. Oliphant et al. Author-email: None License: BSD Location: c:\users\lorraine\appdata\local\autodesk\webdeploy\production\8fc78e02ada35f7bfe8c61944f4c29231b2e06ab\python\lib\site-packages Requires: Required-by: PS C:\Users\lorraine\AppData\Local\Autodesk\webdeploy\production\8fc78e02ada35f7bfe8c61944f4c29231b2e06ab\Python\Scripts>
`pip.main` still doesn't work in the Python interpreter, but importing numpy does -- voilà
Python 3.7.3 (v3.7.3:ef4ec6ed12, Mar 25 2019, 22:22:05) [MSC v.1916 64 bit (AMD64)] on win32 Type "help", "copyright", "credits" or "license" for more information. >>> import pip >>> pip.main Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: module 'pip' has no attribute 'main' >>> import numpy
Link copied
