Hi and thx for using my second add-on for Fusion 360 NoGestures
If you encounter any problem feel free to write in this thread 🙂
Thanks for this attempt and yes, as you, I would prefer to be able to disable right-clic F360 gesture and use right-clic for navigate !
I wonder if it could possible to use RMB for Orbit ? (while MMB stays for Pan as it is already)
Best Regards,
Guy
Have any way use this extension in MacOS (Hight Sierra)?
I am also developer, if you can share sources I can try porting it to Mac OS. As I see, it is requested not only by me 🙂
Thank you!
Yeah you can try but I think it's not easy. https://github.com/pawelzwronek/fusion360-NoGestures
Files to port:
* autohotkey.py
* pyHook/cpyHook.i - wraps '.c' file with SWIG
* build pyHook with build-on-fusion-python.cmd
You can test it by running run-on-fusion-python.cmd as standalone python app.
Good luck 🙂
Hello @pawelzwronek
Great idea to avoid this right-clic gesture.
Could you propose a new version to use right-clic to orbit only (while middle mouse button continues to pan) ?
Say :
MMB = pan
RMB = orbit
As this, we will able to orbit without to have to maintain the [shift] key, and it will be a great progress for freedom !
Thanks again, and I wait your answer with great eagerness 🙂
Cordially,
Guy
Pawel, how it work? I've installed the plugin, but right button is still a matter of Markin menu. I was hoping to get navigation in 3D space like in Rhino.
I've installed the program and the RMB does orbit, but I've lost my ability to right click on any items and get the right click menu. I'm running windows 7 64bit if that helps. I saw another comment on here asking to be able to navigate the same as RHINO and I'll second that vote. I'm not sure if it's possible but this is my desired layout.
RMB hold - Orbit
Shift + RMB - Pan
Progressive Zoom - Ctrl +RMB
Not sure why those three buttons are not configurable in F360 but I still love it.
Try this:
1. Stop NoGestures add-in
2 Right click on NoGestures in Add-Ins window.
3. Click Open file location
4. Edit NoGestures.py
5. Change line 154 and 155 from
fire_in(ahk.RDown, 10)
fire_in(ahk.RUp, 20)
to
fire_in(ahk.RDown, 100) fire_in(ahk.RUp, 200)
6. Run NoGestures again
i am learning some new words in the industry a new learning curve for me
@CapGuy wrote:Hello @pawelzwronek
Say :
MMB = pan
RMB = orbit
Cordially,
Guy
thank you guy
Thank you for replying, I edited the file in notepad with the changes you listed. I didn't notice any difference. That being said I think I now better understand what this tool is meant to do and what I'm want I don't think is going to be possible. I was somehow thinking it could both rotate and do the line menu/right click menu. I see now it's more for getting rid of the line menu all together which I've learned to use and enjoy.
The only thing I could see fixing it 100% is being able to change the RMB from the line menu to something else, leaving the RCB to be programmed to Orbit or Pan.
For future web-searchers like me who stumble onto this discussion, the same author has created the add-in for:
MMB = pan
RMB = orbit
https://apps.autodesk.com/FUSION/en/Detail/Index?id=4978236063737491923&appLang=en&os=Win64
It's precisely what I was looking for, now it has the same binding as Cura. Hallelujah!
@Dangerdad137 : thank you so much for this alert ! 😄
@pawelzwronek : thank you so much for this new version of your excellent plug-in, which now works as I expected in my craziest dreams ! 😄
Best Regards,
Guy
@trash2MDWP8 wrote:Have any way use this extension in MacOS (Hight Sierra)?
Thank you!
Any news on the macOS front? I'm willing to contribute. I have written Python, Obj-C and Swift code, but never combined and never for Fusion 360 😉
As wrote before, you need to port 2 files. Repo is here https://github.com/pawelzwronek/fusion360-NoGestures
Now we have the tinkercad camera control feature, but problem now is the orbit center, could you either make a new addon that is "shift+RMB = set orbit center"? or modify this current one?
Has anybody had problems on the latest update with no gesture?
I can't seem to get it working again. All I get when I use RMB is the select dot. I made sure its running and run on open. Installed re-installed repaired and still I get only select dot.
Any help will be greatly appreciated. I have come to relay on the little app.!!!
Ray
I switched to No Gestures, no Shift, here:
That is not having any trouble on the latest Fusion360.
Can anyone help me??
I can't get this to work. It used to but now when I use the right mouse button all I get is the select tool(draw) or the model menu.
Yes I hold down the RMB but still I get the select. I have reinstalled and repaired many times no luck.
Any help would be greatly appreciated!!
Ray
Yeah, it does not work for me as well... I changed the 154 and 155 line in script as you mentioned and still nothing.
Any ideas ?
Thanks in advance for help.
Ray
