When using the combine command, when the user selects the target body the focus automatically shifts to the tools selection box.
I have a similar UI and would like to know how that focus shift is done.
I tried the tab key but that does not work.
Thanks.
Solved by nnikbin. Go to Solution.
@brad.bylls, in InputChangedEventHandler you can watch the changes of your SelectionCommandInput objects and if one of them changes and its selectionCount is greater than 0, switch the focus to the next SelectionCommandInput using SelectionCommandInput.hasFocus Property
Thanks for the input (pun intended 8^)
I understand what you are saying, but I don't know how to code it.
Can you help.
Of course just after sending you the reply, I figured it out.
Thanks for the help and pointing me in the right direction.
