measureMinimumDistance between 2 occurrences
runeruiterkamp
runeruiterkamp
I'm wondering whether I'm misunderstanding the measureMinimumDistance function. According to the documentation both arguments of this function should be able to accept an Occurrence or a BRepBody:
The first geometry to measure from. This can be an Occurrence, BRepBody, BRepFace, BRepEdge, BRepVertex, ConstructionPlane, ConstructionAxis, ConstructionPoint, and any sketch entity. The only temporary geometry supported is the Plane object.
But when i try to measure the distance between 2 occurrences, or 2 brepbodies:
measureResult = app.measureManager.measureMinimumDistance(occ1body, occ2body)
 I keep getting:
return _core.MeasureManager_measureMinimumDistance(self, geometryOne, geometryTwo)
RuntimeError: 3 : invalid argument geometryOne
(I'm selecting the occurrences using a selectionInput and storing them in an ObjectCollection)
Measuring the minimum distance is possible using the UI measure button so I assumed this should be possible as well, am I missing something? I unfortunately cant find any documentation or examples with this setup, they usually use Lines or Edges.
Thank you
Replies (8)
kandennti
Hi @runeruiterkamp -San.
I was curious so I ran the following script using the attached file.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        app.log(f"** Fusion360 ver{app.version} **")
        # root Body
        rootBody1: fusion.BRepBody = root.bRepBodies[0]
        rootBody2: fusion.BRepBody = root.bRepBodies[1]
        test_measureMinimumDistance(
            "Root Body",
            rootBody1,
            rootBody2,
        # root Face
            "Root Body Face",
            rootBody1.faces[0],
            rootBody2.faces[0],
        # root Edge
            "Root Body Edge",
            rootBody1.edges[0],
            rootBody2.edges[0],
        # root Vertex
            "Root Body Vertex",
            rootBody1.vertices[0],
            rootBody2.vertices[0],
        # occ
        occ1: fusion.Occurrence = root.occurrences[0]
        occ2: fusion.Occurrence = root.occurrences[1]
            "Occurrence",
            occ1,
            occ2,
        # occ body
        occBody1: fusion.BRepBody = occ1.component.bRepBodies[0]
        occBody1 = occBody1.createForAssemblyContext(occ1)
        occBody2: fusion.BRepBody = occ2.component.bRepBodies[0]
        occBody2 = occBody2.createForAssemblyContext(occ2)
            "Occurrence Body",
            occBody1,
            occBody2,
        # occ face
            "Occurrence Body Face",
            occBody1.faces[0],
            occBody2.faces[0],
        # occ Edge
            "Occurrence Body Edge",
            occBody1.edges[0],
            occBody2.edges[0],
        # occ Vertex
            "Occurrence Body Vertex",
            occBody1.vertices[0],
            occBody2.vertices[0],
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def test_measureMinimumDistance(
    msg: str,
    entity1,
    entity2,
) -> None:
    res = is_measureMinimumDistance(
        entity1,
        entity2,
    app.log(f"{msg} -> {res}")
def is_measureMinimumDistance(
    entity1,
    entity2,
) -> bool:
    try:
        measMgr: core.MeasureManager = app.measureManager
        measMgr.measureMinimumDistance(entity1, entity2)
        return True
    except:
        return False
Here are the results.
 ** Fusion360 ver2.0.16490 **
 Root Body -> False
 Root Body Face -> True
 Root Body Edge -> True
 Root Body Vertex -> True
 Occurrence -> False
 Occurrence Body -> False
 Occurrence Body Face -> True
 Occurrence Body Edge -> True
 Occurrence Body Vertex -> True
The measureMinimumDistance method succeeds for face, edge, and vertex, but fails between body and occurrence.
I think this is probably a bug, but I would like to have it fixed as soon as possible, because it is very inconvenient to not be able to perform measurements.
runeruiterkamp
Hi kandennti,
Thank you for verifying this! It's kind of a relief to find that this is probably a bug, since I was almost convinced I was missing something, but the fact that this is possible through the UI Inspect->Measure was suspicious to me.
I'd like to see this fixed as well since I'm relying on this for the add-in I'm trying to develop, is there a place where I can officially report this?
kandennti
As a participant in the Insider Program, there is a system for reporting bugs, so I try to report what I am sure is a bug.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/want-to-get-early-access-to-new-functional...
MichaelT_123
Hi Kandennti-San,
... I haven't tried, ... but consider a small change.
Replace:
# occ body
with:
# occ body
occBody1: fusion.BRepBody = occ1.bRepBodies[0]
Regards
MichaelT
MichaelT
kandennti
Thanks @MichaelT_123 -San.
I tried it and the result was the same.
I had overlooked until now that there is a bRepBodies property in Ocurrence.
This will be useful for other things in the future.
kandennti
If you really want to measure BRepBody with measureMinimumDistance, you can use the TemporaryBRepManager.copy method.
        tmpMgr: fusion.TemporaryBRepManager = fusion.TemporaryBRepManager.get()
            "Root Body-Clone",
            tmpMgr.copy(rootBody1),
            tmpMgr.copy(rootBody2),
            "Occurrence Body-Clone",
            tmpMgr.copy(occBody1),
            tmpMgr.copy(occBody2),
 Root Body-Clone -> True
 Occurrence Body-Clone -> True
runeruiterkamp
Hi kandennti,
Thank you! This is working for me, there doesn't seem to be any downside to using TemporaryBRepManager in my use case so this is perfect.
kandennti
This method can handle the body but not the occurrence.
This bug will be fixed in the near future.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
