Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Keeping a user input dialog open between documents
1 REPLY 1
Joshua.mursic
100 Views, 1 Reply
Hello, is it possible to force a selection input to stay open even when the user changes from one document to another?
1 REPLY 1
kandennti
in reply to: Joshua.mursic
Hi @Joshua.mursic -San.
To keep the dialog from disappearing after switching tabs in the document, it is possible to use a palette.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-F9998A83-E4E7-4EBF-946C-56EC9A37A609
However, I don't think SelectionCommandInput can be used with palettes, so we need to think of another way.
The Command object has a select event, so we might be able to create something similar by using that.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2ACFFC2F-458B-4740-93B8-CCC56638D8AA
I can't think of what the process of switching between documents would look like, but it might be simpler to create two splits and have them run.
