LINK : fatal error LNK1181: cannot open input file 'core.lib'
tperam
tperam
   I am getting the above Link Error on Build of a C++ File in Fusion 360 Microsoft Visual Studio Academic.
Where is file core.lib located?
How can I solve this issue?
Please help.
Thurai
tperam
This happened even after reinstalling Fusion 360.
Thurai
tperam
Fusion 360 Visual Studio is giving the following Error on compiling any Code: LINK : fatal error LNK1181: cannot open input file 'core.lib'
C:\Users\tpera\AppData\Roaming\Autodesk\Autodesk Fusion 360\API\CPP\lib
Fusion Object File Library Updated on June 29, 2020 at 5:10 AM 649 KB
But my Laptop Same Directory Has 3 Files:
Cam, Core, fusion All of them Fusion Object File Library Updated on June 29, 2020 at 5:10 AM.
My Desktop has only one Fusion Object Library file: fusion. May be the Linker in the Desktop is looking for core.lib in the core object library, which is not there. This is a possibility why my Desktop is giving the Link Error LNK1181.
Then I copied the core and cam Fusion Object Files from the Laptop to my Desktop. Then My Desktop Visual Studio Academic Compiled and Linked my C++ File successfully.
So the error Occured because Fusion 360 when updated the Object Library on June 29, 2020 at 5:10 AM did not install the cam and core object Library Files in Windows 10 Professional operating system. My Laptop has regular windows 10 operating system.
Thurai
nnikbin
Thank you so much @tperam for reporting the issue and the solution.
I had the exact same problem on my desktop with Windows 10 Pro. Then as you adviced, I installed Fusion 360 on my laptop (Windows 10 Home) and copied the cam.lib and core.lib from my laptop into Windows 10 Pro machine. The issue resolved.
I will appreciate it if Autodesk publish a patch for this issue ASAP.
tperam
I am glad to have been lucky to find it.
Thurai
