Could not make dll file since july/1st/2020 update.
obatake5TC3R
obatake5TC3R
From the Fusion 360 update of July/1st/2020, compile error and link error come out. The Add-in execution program cannot be created.Even if I create a new Script, I get compile errors and link errors. After checking, core.lib cam.lib is gone. I had no problem before Fusion 360 update July/1st/2020.
obatake5TC3R
I found a bug in the program registered in the App Store (Sketch plus), but I can't fix it.Please respond as soon as possible.
BrianEkins
I've tried reproducing this problem but the libraries are there on my machine.  I thought maybe they were left over from a previous version so I even uninstalled Fusion and cleaned up the folders and when I installed again, the library files were there.  I tried it on both Mac and Windows.  Are you still seeing the problem?  Are you on Mac or Windows?
Brian Ekins
obatake5TC3R
Thank you for your reply.Windows10 pro. I will try re install Fusion360.
obatake5TC3R
After uninstalling Fusion 360 and re-installing it fixed
