Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Is it possible to export an assembly via API?
4 REPLIES 4
michelmarroche
1009 Views, 4 Replies
I am working on a couple of scripts to download and upload projects from cloud to local.
I have already managed to download the projects with their structure and upload them again while maintaining their structure.
Now I am trying to export the designs that have assemblies, I can only do it manually from Export, and this creates a local ".f3z" file .. but I can't find how to do this from within a script ..
Will it be possible?
Thank you !
4 REPLIES 4
kandennti
in reply to: michelmarroche
Hi @michelmarroche .
I found a way to export in the same way as the GUI.
    app.executeTextCommand(u'data.fileExport f3z')
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/master/TextCommands/TextCo...
It takes a lot of time because it is the same as GUI.
michelmarroche
in reply to: kandennti
Hi @kandennti thank you very much !
I will try it!
If it takes a while but allows the assemblies to be properly backed up, it will work!
kandennti
@michelmarroche .
I didn't notice it when I wrote it, but I received a lot of emails ...
ryansmith_
Thanks for this post @kandennti and your post on Fusion360_Small_Tools_for_Developers/TextCommands/TextCommands_txt_Ver2_0_8176.txt at master · kanto....
I'm trying to reliably export f3z files that require cloud translation. The following works in a python script to set the location but doesn't allow for name changes.
            textCommand = f'data.fileExport f3z "{output_folder_path}"'
            app.executeTextCommand(textCommand)
I was able to get a new name and location using the neu_server.export in the Text Command window but not in a python script.
neu_server.export(r'C:\Users\<username>\OneDrive\Fusion 360 Data\test.f3z')
Do you know a way to run this from python?
I'm also finding that renaming a Document is not allowed and renaming a dataFile by dataFile.name = newName works for the dataFile but doesn't reliably update the Document.name, which is the name used in exports. Have you found any way to work through this?
