Hi everyone,
I'm trying to automate importing a batch of stl files into fusion 360 and converting them to B-REP (the button under mesh --> modify --> convert mesh) using python. Is there any documentation on this?
Thank you!
Best,
Sounak
Solved by kandennti. Go to Solution.
Hi @Anonymous .
I converted the OBJ file to BRepBody here. I think it can be used in STL with a few modifications.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/insert-obj-file/m-p/9640466#M10730
However, if the number of faces in one body is more than 10,000, a warning dialog appears, and if the number of faces is more than 50,000, it cannot be processed. This is the same even if you use the GUI.
To avoid this problem, here is a sample of how to split a body until the number of faces in a body is less than 10000, and then convert it.
However, it is all written in Japanese.
Hi kandennti ,
Thank you for the python script examples. I've modified the first script to import an STL file. However, I noticed that file explorer pops up, and I still need to manually click on the file I want to work with. Is there any way to automate this part by adding a file path? I've included the modified code below. I mainly changed lines 15, 49, and 80.
Thank you!
Best,
Sounak
# Fusion360API Python script by kantoku
# Mesh2BRep sample
# Changed to Import STL
import adsk.core, adsk.fusion, traceback
_app = adsk.core.Application.cast(None)
_ui = adsk.core.UserInterface.cast(None)
def run(context):
try:
global _app, _ui
_app = adsk.core.Application.get()
_ui = _app.userInterface
# select files
paths = selectFiles('select STL file')
if not paths: return
# new doc
_app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
des :adsk.fusion.Design = _app.activeProduct
des.designType = adsk.fusion.DesignTypes.ParametricDesignType
root :adsk.fusion.Component = des.rootComponent
# baseFeature
baseFeatures = root.features.baseFeatures
baseFeature = baseFeatures.add()
baseFeature.startEdit()
# import obj files
meshs = importMesh(paths ,root.meshBodies, baseFeature)
# Mesh2BRep
#execMesh2BRep(meshs)
#baseFeature.finishEdit()
# finish
_ui.messageBox('Done')
except:
if _ui:
_ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def execMesh2BRep(
meshBodies):
# select meshBody
for mesh in meshBodies:
_ui.activeSelections.add(mesh)
# show Mesh2BRep Command dialog
_app.executeTextCommand(u'Commands.Start Mesh2BRepCommand')
# push OK button
_app.executeTextCommand(u'NuCommands.CommitCmd')
def importMesh(
paths :list,
meshBodies :adsk.fusion.MeshBodies,
baseFeature :adsk.fusion.BaseFeature) -> list:
unitCm = adsk.fusion.MeshUnits.CentimeterMeshUnit
bodies = []
for path in paths:
meshLst = meshBodies.add(path, unitCm, baseFeature)
[bodies.append(mesh) for mesh in meshLst]
return bodies
def selectFiles(
msg :str):
fileDlg = _ui.createFileDialog()
fileDlg.isMultiSelectEnabled = True
fileDlg.title = msg
fileDlg.filter = '*.stl'
dlgResult = fileDlg.showOpen()
if dlgResult == adsk.core.DialogResults.DialogOK:
return fileDlg.filenames
@Anonymous .
The CommandID of the mesh transformation has been changed and is now fixed.
Enter the path of the desired STL file in the "paths" variable to avoid specifying the file in the dialog.
import adsk.core
import adsk.fusion
import traceback
def run(context):
try:
global _app, _ui
# import stl files list
paths = [
r'C:\temp\hoge.stl',
r'C:\temp\piyo.stl',
# new doc
# baseFeature
# import obj files
# Mesh2BRep
# finish
except:
if _ui:
def execMesh2BRep(
meshBodies):
# select meshBody
# show ParaMeshConvertCommand Command dialog
_app.executeTextCommand(u'Commands.Start ParaMeshConvertCommand')
# push OK button
def importMesh(
paths :list,
bodies = []
for path in paths:
return bodies
Hi kandennti,
Thank you for the help! Here's the new code implementing the ParaMeshConvertCommand.
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
def run(context):
ui = None
try:
ui = app.userInterface
test_name = '1test_file'
#Find project by name
# Get the root folder of the project
for data_file in app.activeDocument.dataFile.parentFolder.dataFiles:
#if data_file.fileExtension == 'stl':
if test_name == data_file.name:
msg = str(data_file.name)
ui.messageBox(msg)
app.documents.open(data_file)
des :adsk.fusion.Design = app.activeProduct
sels :adsk.core.Selections = ui.activeSelections
sels.clear()
cmDefs = ui.commandDefinitions
for mesh in root.meshBodies:
msg = str(mesh.name)
ui.messageBox(msg)
sels.add(mesh)
# push OK button
#cmDef = cmDefs.itemById("ParaMeshConvertCommand")
#cmDef.controlDefinition.isEnabled
#cmDef.execute()
msg = 'brep conversion complete'
ui.messageBox(msg)
except:
if ui:
I looked at your other examples on how to select meshes. Before, I saw your most recent reply, I was actually trying to use the commandDefinitions to execute the ParaMeshConvert command. If you comment out the text commands and uncomment the commandDefinition lines, I got to the point where I just needed to press the enter key. Just out of curiosity, would you know how I can use keyboard events?
Again, thank you for the help!
Best,
Sounak
