Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
In scripts dialog please default to last used
0 REPLIES 0
Message 1 of 1
RogerInHawaii
331 Views, 0 Replies
When you select Add-Ins -> Scripts and Add-Ins the dialog that pops up always defaults to the first item in Sample Scripts section.
Instead, could you please have it remember which script was actually selected by the user the last time that the dialog was brought up and make THAT the default selection? When we're doing a lot of running and diagnosing of a particular script it just becomes annoying that we have to specifically select the one we want every single time.
In fact, it would be GREAT if there was an easy way to specify that a particular script should appear directly in the menu that pops up when you click on the Add-Ins item in the main menu so that we could more quickly start up the desired script.
0 REPLIES 0
