identity matrix - causing problems
MichaelT_123
Advisor Advisor
MichaelT_123
Hi WhomInTheKnow,
I have spent quite few hours trying to debug some dynamic code. I would have never considered that identity matrix will show malicious behaviour, but it did!
It turns that moveFeature can not accept identity matrix as an argument.
It is hard to believe, isn't it?
Please check it yourself by running moveFeature sample script while commenting one line (red marker):
        # Create a transform to do move
        vector = adsk.core.Vector3D.create(0.0, 10.0, 0.0)
        transform = adsk.core.Matrix3D.create()
        #transform.translation = vector
The error is symptomatically cryptic:
    moveFeats.add(moveFeatureInput)
  File "C:/Users/MichaelT/AppData/Local/Autodesk/webdeploy/production/20eba7b8590bd15aa5cf30169381ceca41f2dc77/Api/Python/packages\adsk\fusion.py", line 18803, in add
    return _fusion.MoveFeatures_add(self, *args)
RuntimeError: 3 : invalid transform
Sincerely
MichaelT
MichaelT
kandennti
Hi MichaelT_123.
I tried changing this sample.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-153E540B-6246-460C-8B6A-4C58165CEBAA
Certainly an error occurred.
Since there is no point in converting with the identity matrix,
It seems necessary to check in advance.
        if transform.isEqualTo(adsk.core.Matrix3D.create()):
            return
        # Create a move feature
        moveFeats = features.moveFeatures
In the conversion that does nothing even manually, the OK button was gray and could not be pressed.
MichaelT_123
Hi Kondennti-san,
Thank you for checking,... it means that it is not the fatamorgana.
Identity matrix is the foundation of ALGEBRA as we know it. Also Identity has the special and well understood meanings in many other fields.
Disallowing or disobeying its properties in any system and particularly in geometrical one is a NONSENSE.
With Regards
MichaelT
MichaelT
