I can't add a script
Rosie_roses
Rosie_roses
I'm trying to follow this tutorial:
https://www.instructables.com/3D-CNC-Relief-Sculpture-Fusion-360/
To do so I need to add a script in the scripts and add-ins menu.
When I try to add the script I get this error message:
"A single script or add-in cannot be identified in the selected folder. Please organize your programs so each script or add-in is in its own folder."
I have heard that you need the PointAtCoord file or folder? so When I go to
>>>AppData\Roaming\Autodesk\Autodesk Fusion 360\API\Scripts
It is totally empty, I've heard somewhere else that you should have a PointAtCoord file or folder? I can't find that anywhere.
Any help welcome.
Many thanks.
JeromeBriot
The easiest way to install the Image2Surface add-in is to use this one: Install scripts or addins from GitHub
Run the add-in and enter the repo URL: https://github.com/hanskellner/Fusion360Image2Surface
