How to offset a sketch circle using the Fusion360 API
EamonKung
EamonKung
How can I offset a sketch circle using the Fusion360 API? Could you please provide a brief C++ code example for reference?
BrianEkins
Here's the full code of a C++ script that works for me.
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
using namespace adsk::core;
using namespace adsk::fusion;
Ptr<Application> app;
Ptr<UserInterface> ui;
extern "C" XI_EXPORT bool run(const char* context)
    app = Application::get();
    if (!app)
        return false;
    ui = app->userInterface();
    if (!ui)
        return false;
    // Get the root component from the active design and create a sketch.
    Ptr<Design> des = app->activeProduct();
    Ptr<Component> root = des->rootComponent();
    Ptr<Sketch> sk = root->sketches()->add(root->xYConstructionPlane());
    // Draw a circle.
    Ptr<SketchCircles> circles = sk->sketchCurves()->sketchCircles();
    Ptr<SketchCircle> circle = circles->addByCenterRadius(adsk::core::Point3D::create(0, 0, 0), 5);
    // Offset the circle.
    Ptr<GeometricConstraints> constraints = sk->geometricConstraints();
    std::vector<Ptr<SketchCurve>> curves;
    curves.push_back(circle);
    Ptr<OffsetConstraintInput> input = constraints->createOffsetInput(curves, adsk::core::ValueInput::createByReal(1));
    Ptr<OffsetConstraint> offset = constraints->addOffset2(input);
    std::vector<Ptr<SketchCurve>> resultCurves = offset->childCurves();
    Ptr<SketchCircle> newCircle = resultCurves[0];
    ui->messageBox("The offset circle is " + std::to_string(newCircle->radius()) + " cm radius.");
    return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
    switch (reason)
    case DLL_PROCESS_ATTACH:
    case DLL_THREAD_ATTACH:
    case DLL_THREAD_DETACH:
    case DLL_PROCESS_DETACH:
        break;
    return TRUE;
#endif // XI_WIN
Brian Ekins
EamonKung
Thanks a lot for your response.
MichaelT_123
Hi Mr  EamonKung,
It is known that an offset of a circle is also a circle, the concentric one, with changed by the offset value radius.
Yes, it is possible to complicate things, but what for?
Regards
MichaelT
MichaelT
