How can you delete a Component?
hassan2516
hassan2516
I am using the CombineCut tool to create a new component by setting the isNewComponent to True.  I cannot figure out how to delete the new component from the browser at the end of the script.  I can delete the new Body by using newBody.deleteMe() but there is no deleteMe method on Components.  How can you delete a Component?
Scott
Here is a snippet of my code:
CombineCutInput = rootComp.features.combineFeatures.createInput(targetBody, toolBodies)
CombineCutInput.operation = adsk.fusion.FeatureOperations.IntersectFeatureOperation
CombineCutInput.isKeepToolBodies = True
CombineCutInput.isNewComponent = True
ret = rootComp.features.combineFeatures.add(CombineCutInput)
newBody = ret.bodies.item(0)
newComponent = newBody.parentComponent
newBody.deleteMe()
BrianEkins
It's not a component that you see in the browser but is an occurrence that references a component. Components can't be directly deleted but the Occurence object supports the deleteMe method and if all the occurrences that reference a particular component are deleted, Fusion will automatically delete the component.
Brian Ekins
hassan2516
Ahhh...  that did the trick.  Here is the code to remove the component by using the rootComp and searching for the newly created component.
Scott
## delete the newly created component from the intersection
for occurrence in rootComp.occurrencesByComponent(newComponent):
     occurrence.deleteMe()
hassan2516
I went one step further by making a class method on Component called deleteMe so that you can just call deleteMe on a component to delete it.
Scott
def component_deleteMe(self):
  app = adsk.core.Application.get()
  product = app.activeProduct
  design = adsk.fusion.Design.cast(product)
  rootComp = design.rootComponent
  for occurrence in rootComp.occurrencesByComponent(self):
adsk.fusion.Component.deleteMe = component_deleteMe
