I have imported a simple 3d-mesh (obj-File) and I'm wondering if it possible to do a 'Generate Face Groups' via script?
In the end I need the edges of each FG afterwards... (seems to me similar to the BRepEdges - stuff, but I don't know how to generate them). I'm new to the fusion API, so many thnx for any help!!
BR gerhard
Solved by kandennti. Go to Solution.
Solved by tomas.bangoA2EPZ. Go to Solution.
Seems my question cannot be answered, maybe the API function which I asked for is not available?
Is there another way to create a BRep from a Mesh and then access the BRepEdges?
Thnx for any help...
Hi I'm sure there is a solution that at least comes close. Not all features need to be accessible through the Fusion API but that doesn't have to stop you right away.
A first option would be to use 3rd party libraries (for example PyAutoGui) and simulate the user clicking on the "Generate Face Groups" button.
The second option would be to find the command directly through adsk.core.Application.userInterface and run it with the execute.
Hi Tomas,
many thnx for your reply. For me it is not the big problem not having the 'Generate Face Groups' function (your PyAutoGui is a great idea anyway). Sorry my missleading info:
My problem is: I need the DATA of the face groups itself (or BRepEdge data). I don't know how to access it via python script... I tried to acess via
Mesh body cannot be found among BRepBodies because Mesh are not BRep from the definition of these objects.. You need to convert Mesh to BRep first and then the converted body will be available from BRepBodies.
Hi @ferdlhons -San.
We have created a sample script that executes 'Generate Face Groups' using the text command.
After running the script, select MeshBody.
# Fusion360API Python script
import traceback
import adsk.core as core
import math
def run(context):
ui: core.UserInterface = None
try:
app: core.Application = core.Application.get()
ui = app.userInterface
msg: str = "Select MeshBody"
selFilter: str = "MeshBodies"
sel: core.Selection = select_ent(msg, selFilter)
if not sel:
return
exec_mesh_calculate_faceGroups_Command(5.0, 0.1)
ui.messageBox("Done")
except:
if ui:
ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
def exec_mesh_calculate_faceGroups_Command(
infoOpeningAngle: float = 25.0,
infoFastSegmentArea: float = 0.2,
cmds = [
u"Commands.Start ParaMeshCalculateFaceGroupsCommand",
u"Commands.SetString infoSegmentationMethod {}".format(
"infoSegmentationMethodFast"
u"Commands.SetDouble infoOpeningAngle {}".format(
math.radians(infoOpeningAngle)
u"Commands.SetDouble infoFastSegmentArea {}".format(
infoFastSegmentArea
u"NuCommands.CommitCmd",
[app.executeTextCommand(cmd) for cmd in cmds]
def select_ent(
msg: str,
filter: str
) -> core.Selection:
try:
ui: core.UserInterface = app.userInterface
sel = ui.selectEntity(msg, filter)
return sel
except:
return None
@ferdlhons -San.
I have created a script to create a sketch of the FaceGroup boundary.
Note that this is a very slow process.
import traceback
import adsk
import adsk.fusion as fusion
import math
def run(context):
try:
des: fusion.Design = app.activeProduct
des.designType = fusion.DesignTypes.ParametricDesignType
# select mesh
if not sel: return
baseMesh: fusion.MeshBody = sel.entity
# face group
exec_mesh_calculate_faceGroups_Command(baseMesh, 5.0, 0.1)
# mesh extract
meshes = exec_mesh_extract(baseMesh)
# mesh to brep
breps = meshes_to_brepBodies(meshes)
# open edges
openEdgesLst = get_open_edges_by_bodies(breps)
# draw edges - sketch
comp: fusion.Component = baseMesh.parentComponent
draw_edges_by_edgesList(comp, openEdgesLst)
# remove
[x.deleteMe() for x in meshes]
breps[0].deleteMe()
baseMesh.isLightBulbOn = True
except:
if ui:
def draw_edges_by_edgesList(
comp: fusion.Component,
edgesLst: list[list[fusion.BRepEdge]],
) -> list[fusion.Sketch]:
sktLst = []
for edges in edgesLst:
sktLst.append(
draw_edges(comp, edges)
adsk.doEvents()
return sktLst
def draw_edges(
edges: list[fusion.BRepEdge],
) -> fusion.Sketch:
if len(edges) < 1: return
skt: fusion.Sketch = comp.sketches.add(
comp.xYConstructionPlane
skt.name = "Mesh Group Open Edge"
objs: core.ObjectCollection = core.ObjectCollection.createWithArray(
edges
for x in edges:
if not x.classType() == fusion.SketchLine.classType():
print("K")
else:
print("V")
skt.isComputeDeferred = True
skt.include(objs)
skt.isComputeDeferred = False
for crv in skt.sketchCurves:
crv.isReference = False
crv.isFixed = True
def get_open_edges_by_bodies(
bodies: list[fusion.BRepBody],
) -> list[list[fusion.BRepEdge]]:
openEdgesLst = []
for body in bodies:
openEdgesLst.append(
[e for e in body.edges if e.coEdges.count < 2]
return openEdgesLst
def meshes_to_brepBodies(
meshes: list[fusion.MeshBody],
) -> list[fusion.BRepBody]:
if not meshes: return
if len(meshes) < 1: return
comp: fusion.Component = meshes[0].parentComponent
beforeLst = list(comp.bRepBodies)
sels: core.Selections = app.userInterface.activeSelections
sels.clear()
[sels.add(m) for m in meshes]
cmds = [
u"Commands.Start ParaMeshConvertCommand",
u"Commands.SetString ConvertMeshInfoOperation {}".format(
"infoOperationNewBaseFeature"
u"Commands.SetString MeshToBREPAlgorithmInput {}".format(
"infoMethodTriangleBased"
return [m for m in comp.bRepBodies if not m in beforeLst]
def exec_mesh_extract(
mesh: fusion.MeshBody,
) -> list[fusion.MeshBody]:
if not mesh: return
comp: fusion.Component = mesh.parentComponent
beforeLst = list(comp.meshBodies)
sels.clear()
sels.add(mesh)
cmds = [
u"Commands.Start ParaMeshExtractCommand",
u"Commands.SetString infoType {}".format(
"infoTypeAllFaceGroups"
u"Commands.SetBool infoPreserveSourceBody 1",
return [m for m in comp.meshBodies if not m in beforeLst]
sels.clear()
sels.add(mesh)
cmds = [
infoFastSegmentArea
def select_ent(
msg: str,
filter: str
try:
return sel
except:
return None
this is amazing - for me as newby this is very helpful lession how to get access to the data! Thank you so much for this, I will try this today evening...
BR Gerhard
