Extrude Pipe/Sweep through imported lines from csv
haik.vasil.3
haik.vasil.3
I am looking for an extension to the wonderful script made by @hanskellner
https://github.com/hanskellner/Fusion360ImportCSVPoints
I am trying to extrude a Pipe through the imported Line. I have seen a script for just Pipe Extrusion, and little confused... It seems there is no Pipe command in API but only Sweep.
JeromeBriot
Actually, you can only access existing Pipe feature with the API: PipeFeatures Object
However, a non-trivial and unofficial workaround exists: Use TextCommands
haik.vasil.3
haik.vasil.3
@JeromeBriot Thanks for the Reference! a great way around.
So what I understand Pipe command exists only as a Text command, right? Otherwise, I need to refer to the Sweep command, creating a construction Plane at each Line to draw a Profile and extrude...
JeromeBriot
Yes
hanskellner
Hi @haik.vasil.3 -
I've updated the add-in with support to create pipes.  See the README:
https://github.com/hanskellner/Fusion360ImportCSVPoints/blob/master/README.md#pipes
Please grab the new version from the Github repo and install and try it.
Note, very complex paths (lines, splines) may cause Fusion 360 to lockup while attempting to create the geometry.
Cheers,
Hans
Hans Kellner
Senior Manager, Principal Engineer
haik.vasil.3
Fantastic, thanks @hanskellner
