I have a selection input that only accepts sketch points, and want to draw a circle on top of whichever points are clicked. This function is hooked up to executePreview:
def update_sketch(self):
ao = apper.AppObjects()
if not self.sketch:
sketches = ao.root_comp.sketches
self.sketch = sketches.add(self.currentSelection[0].parentSketch.referencePlane)
else:
for obj in self.sketch.sketchCurves:
if obj.isValid:
obj.deleteMe()
for point in self.currentSelection:
self.sketch.sketchCurves.sketchCircles.addByCenterRadius(point.geometry, 2)
To me, it seems like this function should create a fresh sketch if it does not exist, and delete all existing curves if it does. After, for each selected point, add a circle.
The actual behavior upon testing is that when only one point is selected, everything works great. However, when another point is selected, the following error is thrown:
File "C:/Users/k/AppData/Local/Autodesk/webdeploy/production/48ac19808c8c18863dd6034eee218407ecc49825/Api/Python/packages\adsk\fusion.py", line 32381, in addByCenterRadius
return _fusion.SketchCircles_addByCenterRadius(self, centerPoint, radius)
RuntimeError: 4 : An API Object refers to a deleted Object
and the original circle disappears (even with the deletion code removed).
What am I doing wrong?
Solved by kandennti. Go to Solution.
Each time the executePreview event is fired, you do whatever work is needed to create a preview. All that work is contained within a single transaction. The next time the executePreview is fired, the transaction is aborted, taking back to the state when the command was first invoked, and allowing you to draw the next preview, which will be captured in a new transaction. This means you are not building on top of any previous work done in this invocation of the command but are building from scratch for each preview.
Correct me if I am wrong, but in the class I am using to manage these events I am using a property to save the selection information. At that point, it is using a reference to the selection in the command inputs. Does this mean that I have to deep copy the information to properly save it? Not quite sure if I understand what you are saying. . .
Hi @keithJHSV9 .
I could not reproduce it because I could not try it with that only source code.
I have created this add-in using Apper.
Every time I select a point in the sketch, I use the executePreview event to call this function.
As far as I am aware, anything created by the executePreview event will be deleted by itself before the next event fires.
To clarify what I was saying, here's what you need to do for your specific case.
When your command is running and the user selects a point, the executePreview event is fired. In reaction to the event, you create a sketch and use the selected point to draw a sketch circle.
When they select a second point, the executePreview is again fired. As part of the execute preview event firing, Fusion has aborted all work that was done in the previous executePreview. Which means you're starting from scratch and need to create a sketch and now draw two circles because two points have been selected.
Selecting more points, results in the same process of aborting all previous work and you creating a sketch and drawing a circle for each selected point.
If the user unselects a point the same thing happens and the result is correct because you're again creating a new sketch and drawing a circle for each selected point. This time the unselected point is ignored because it's not in the set of selected entities.
The main thing to understand is that each time the executePreview event fires that you are not just creating the changes from the last executePreview but are creating everything again because it was all removed as a result of Fusion aborting all of the previous work.
