Hello
I followed the directions and placed the add-in go DogBones from Github. It showed up and appeared to work. When I closed the application and came back to it. The changes were now gone. It shows the add in still there and working but it is not working. I have removed and reinstalled a number of times and no luck. Any ideas on how to fix this problem.
Peter
It would be great if you can screencast to demonstrate your issue.
Marshal
There is 2 picture. One picture is the location of the file and other is it in the add ins menu.
Please check if the option "Run on Startup" is checked with that addin. If not, the addin will not run when you relaunch Fusion 360. You have to run it manually then.
Marshal
Yes it is checked. The add in is no where to be found. If you remove a tool from the toolbar where can you find it. Basically it should be next to sketch from what I have seen from others.
Unfortunately I still have no idea what's the problem. It would be great if you can record a video to demo your issue.
Marshal
