When writing scripts for the fusion 360 API one could use `sk = root.sketches.add(root.xYConstructionPlane)` to create a sketch plane to add points to. But is it possible to create a arbitrary plane given a normal or base vectors from global coordinates?
Solved by kandennti. Go to Solution.
Hi Erikvk.
After executing the script, click the face to create a tangent plane.
It continues until the ESC key is pressed.
#Fusion360API Python Script #Author-kantoku #Description-CreatePlane ClickPoint import adsk.core, adsk.fusion, traceback def run(context): ui = None try: app = adsk.core.Application.get() ui = app.userInterface des = adsk.fusion.Design.cast(app.activeProduct) root = des.rootComponent planes = root.constructionPlanes msg = 'Click on the face / End is ESC key' skt = None while True: sel = SelectEnt(ui, msg, 'Faces') if sel is None: break if skt is None: skt = root.sketches.add(root.xYConstructionPlane) pnt = skt.sketchPoints.add(sel.point) InitPlane(planes, sel.entity, pnt) ui.messageBox('Done') except: if ui: ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def InitPlane( plns :adsk.fusion.ConstructionPlanes, surf :adsk.fusion.BRepFace, pnt :adsk.core.Point3D): plnInput = plns.createInput() if plnInput.setByTangentAtPoint(surf, pnt): plns.add(plnInput) def SelectEnt( ui :adsk.core.UserInterface, msg :str, filtter_str :str) -> adsk.core.Selection : try: selection = ui.selectEntity(msg, filtter_str) return selection except: return None
enjoy!
