code review/share for automated change of parameters and stl-export
picadilly
picadilly
I do an open-source-project called osVAC neo. For details see: osvacneo.de
It is similiar to plumbing:
you have a few basic parts, like bows and T-connectors, but you need them in lots of different sizes and combinations thereof.
So, I did the designs in f360 and to get the different sizes I change parameters.
To generate the stl-files I have to:
1) change the desired parameters
2) exports part(s) als stl (and step-files)
3) repeat the above for all desired combinations of parameters
Now, I have a first decent prototype up and running. I would like to share the code and would appreciate comments. I will also attach my f360-test-design.
Brief description, how to use:
There ist a section in the code, where you place your user parameters und values:
        # change to your personal data here
        inputData1 = (
            ("height", (10, 20)),
            ("width", (30, 40)),
            ("length", (50,60))
        inputData2 = (
            ("MaleDiameterInner", (25, 32, 36, 40, 50)),
            ("FemaleDiameterInner", (25, 32, 36, 40, 50))
        inputData = inputData1
        destFolder = "D:\\tmp\\F360"
        # end of personal data
The program will iterate and build every possible permutation of the give values (for inputData1 there are 8 permutations, for inputData2 there are 25) and generate a properly named stil-file:
picadilly
And here comes the code:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, os, traceback
def get_immediate_children(component):
    # Get the child occurrences (components) directly under the specified component
    child_occurrences = component.occurrences
    # Extract the actual component objects from the occurrences
    child_components = [occ.component for occ in child_occurrences if occ.isVisible]
    return child_components
def _generateIteratedDataSet( inputDataSets, oneDataLine, iteratedData ):
    index = len(oneDataLine)
    if( index < len(inputDataSets) ):
        inputDataSet = inputDataSets[index][1]
        for data in inputDataSet:
            oneDataLine.append( data )
            oneDataLine.pop(index)
    else:
        tmp = oneDataLine.copy()
        iteratedData.append(tmp)
def generateIteratedDataSet( inputDataSets ):
    names = []
    for inputDataSet in inputDataSets:
        names.append( inputDataSet[0] )
    interatedData=[]
    _generateIteratedDataSet( inputDataSets, [], interatedData)
    return( (names, interatedData) )
def verifyUserParameters(app, design, names):
    ui = app.userInterface
    userParameters = design.userParameters
    for name in names:
        userParameter = userParameters.itemByName(name)
        if userParameter:
            dummy = 1
        else:
            ui.messageBox('User-Parameter "{}" nicht gefunden.'.format(parameterName), 'Fehler')
            return
def setUserParameters(app, design, names, data):
    length = len(names)
    for index in range(0, length, 1):
        name = names[index]
        val = data[index]
        userParameter.expression = str(val)
    # update parametric text plugin
    app.fireCustomEvent('thomasa88_ParametricText_Ext_Update')
    adsk.doEvents()
    adsk.doEvents()
    dummy = 1
def generateFileName( componentName, names, data ):
    length = len(names)
    text = ""
        name = names[index]
        val = data[index]
        if( len(text) != 0 ):
            text = text + "-"
        text = text + name + "=" + str(val)
    text = componentName + "-" + text
    dummy = 1
    return( text )
def exportStl( exportMgr, component, destFolder, fnBody ):
    fn = os.path.join( destFolder, fnBody + '.stl')
    stlOptions = exportMgr.createSTLExportOptions(component, fn)
    stlOptions.sendToPrintUtility = False # Setze auf True, wenn du die Exportdatei direkt drucken möchtest
    # Körper als STL exportieren
    exportMgr.execute(stlOptions)
def run(context):
    ui = None
    try:
        # Zugriff auf Fusion 360 UI
        app = adsk.core.Application.get()
        # Dokument und Design erhalten
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('Kein aktives Fusion 360 Design.', 'Fehler')
            return
        # Get the root component
        root_component = design.rootComponent
        # Get the immediate child components under the root component
        immediate_children = get_immediate_children(root_component)
        inputData1 = (
            ("length", (50,60))
        inputData2 = (
        iteratedDataSet = generateIteratedDataSet( inputData )
        names = iteratedDataSet[0]
        iteratedData = iteratedDataSet[1]
        verifyUserParameters( app, design, names )
        for data in iteratedData:
            setUserParameters( app, design, names, data )
            exportMgr = design.exportManager
            for component in immediate_children:
                fnBody = generateFileName( component.name, names, data )
                dummy = 0
        dummy=1
        return
        # dead old code below
        # User-Parameter ändern
        parameterName = 'HoseDiameterInner'  # Name des zu ändernden Parameters
        parameterObj = ui.inputBox("Bitte geben Sie den Namen des Parameters ein:", "Parameter Name", "HoseDiameterInner")
        parameterName = parameterObj[0]
        # Überprüfen, ob der Benutzer einen Namen eingegeben hat
        if not parameterName:
            ui.messageBox("Es wurde kein Parametername eingegeben.")
            return
        for parameterValue in [25, 32, 36]:
            set_parameter(app, design, parameterName, parameterValue)
            # Export
                export_stl(exportMgr, component, parameterValue)
        ui.messageBox('Export erfolgreich abgeschlossen.')
    except:
        if ui:
            ui.messageBox('Fehler aufgetreten:\n{}'.format(traceback.format_exc()))
picadilly
nobody interested into this? I guessed, that some users out there would have similiar requirements and would be curious, how they are doing?
