I am unable to create a pattern on a path feature using the Fusion 360 API.
I ask the user to select a component and multiple paths to pattern that component along. I then loop over those paths and create a pattern on path feature for each path, using the same component every time. But when I do that it comes up with an error.
This is my code:
import adsk.core, adsk.fusion, adsk.cam, traceback
handlers = []
app = adsk.core.Application.get()
if app:
ui = app.userInterface
class PatternMultipPathsCommandExecuteHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
def notify(self, args):
try:
command = args.firingEvent.sender
component = command.commandInputs.itemById("component").selection(0).entity
paths_selection = command.commandInputs.itemById("paths")
paths = [paths_selection.selection(i).entity for i in range(paths_selection.selectionCount)]
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
rootComp = design.rootComponent
features = rootComp.features
inputEntites = adsk.core.ObjectCollection.create()
inputEntites.add(component)
for item in paths:
path = features.createPath(item)
quantity = adsk.core.ValueInput.createByString('3')
distance = adsk.core.ValueInput.createByString('1 cm')
pathPatterns = features.pathPatternFeatures
pathPatternInput = pathPatterns.createInput(inputEntites, path, quantity, distance,
adsk.fusion.PatternDistanceType.SpacingPatternDistanceType)
pathFeature = pathPatterns.add(pathPatternInput)
except:
if ui:
ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
class PatternMultipPathsCommandDestroyHandler(adsk.core.CommandEventHandler):
def __init__(self):
super().__init__()
try: adsk.terminate()
except:
if ui:
class PatternMultipPathsInputChangedHandler(adsk.core.InputChangedEventHandler):
def __init__(self):
super().__init__()
try:
eventArgs = adsk.core.InputChangedEventArgs.cast(args)
cmdInput = eventArgs.input
if cmdInput.id == "component":
command.commandInputs.itemById("paths").hasFocus = True
except:
if ui:
class PatternMultipPathsCommandCreated(adsk.core.CommandCreatedEventHandler):
def __init__(self):
super().__init__()
try:
cmd = args.command
cmd.setDialogInitialSize(300, 150)
onExecute = PatternMultipPathsCommandExecuteHandler()
cmd.execute.add(onExecute); handlers.append(onExecute)
onDestroy = PatternMultipPathsCommandDestroyHandler()
cmd.destroy.add(onDestroy); handlers.append(onDestroy)
onInputChanged = PatternMultipPathsInputChangedHandler()
cmd.inputChanged.add(onInputChanged); handlers.append(onInputChanged)
inputs = cmd.commandInputs
i1 = inputs.addSelectionInput("component", "Component",
(" " * 3)+"Select a component to be patterned.")
i1.setSelectionLimits(1, 1); i1.addSelectionFilter("Bodies")
i2 = inputs.addSelectionInput("paths", "Paths",
(" " * 3)+"Select paths to pattern a component along.")
i2.setSelectionLimits(1); i2.addSelectionFilter("Edges")
except:
if ui:
def run(context):
try:
commandDefinitions = ui.commandDefinitions
# check the command exists or not
cmdDef = commandDefinitions.itemById("PatternMultipPaths")
if not cmdDef:
cmdDef = commandDefinitions.addButtonDefinition("PatternMultipPaths",
"Pattern Along Multiple Paths",
"Do a component pattern along multiple paths.")
onCommandCreated = PatternMultipPathsCommandCreated()
cmdDef.commandCreated.add(onCommandCreated)
handlers.append(onCommandCreated)
inputs = adsk.core.NamedValues.create()
cmdDef.execute(inputs)
adsk.autoTerminate(False)
except:
if ui: ui.messageBox("Failed:\n{}".format(traceback.format_exc()))
And this is the error I get:
Traceback (most recent call last):
File "C:/Users/Bevis Hobbs/AppData/Roaming/Autodesk/Autodesk Fusion 360/API/Scripts/Pattern along multiple paths/Pattern along multiple paths.py", line 37, in notify
File "C:/Users/Bevis Hobbs/AppData/Local/Autodesk/webdeploy/production/eba7fbfbb17ff9a9d7c25530f6f766b5ffb15678/Api/Python/packages\adsk\fusion.py", line 27228, in add
return _fusion.PathPatternFeatures_add(self, input)
RuntimeError: 5 : Some input argument is invalid.
Solved by bevis.hobbs21. Go to Solution.
Hi @bevis.hobbs21 .
I tried it and did not get any errors.
What kind of data do I need to try to get an error?
Not sure if it's a bug in Fusion 360 but the component I was selecting is a derived component and when I broke the link on the derived component the script worked perfectly.
