Can I change my Toolbar options
RandyKopf
RandyKopf
Hi
Curious... I have a CAM toolbar I'd like to swap out commands, so that Generate Toolpath would reside where the SetupSheet is on Toolbar.
I never use setup sheets and always use Generate Toolpath.
Is this possible?
Thank you!
Randy Kopf
http://desktopartisan.blogspot.com/
If my post is helpful, press the LIKE Button If it resolves your issue, press Accept as Solution! Have a great day!
ekinsb
Fusion supports toolbar customization without requiring you to write any programs.  Next to each command in the drop-down associated with each panel it will have either a remove or an add icon depending on if it's already displayed in the toolbar or not.  Clicking add will move it to the toolbar and clicking remove will take it off.  You can see the result of my toolbar below.  You can do this for any of the toolbars to easily customize them to make them better fit how you use Fusion.
Brian Ekins
Mod the Machine blog
RandyKopf
Thank you that was easy!
Randy Kopf
