Restricting selections for SelectionCommandInput
nnikbin
nnikbin
Is there any way for restricting selections for SelectionCommandInput, beyond what "Selection Filters" provide?
For example when you select Pattern Bodies in Rectangular Pattern, after selecting the first body, you can only select other bodies whose parent are the same as the parent of the first selected body. Even hovering over the other bodies whose parents are different, does not make them highlighted (please refer to the linked screencast).
Is it possible to implement this kind of behavior using Fusion 360 API?
Navid
liujac
SelectionEvent may support this requirement.
"The selectionEvent event is a command event but only applies when you have added selectionCommandInput objects to your dialog. This event provides two capabilities; dynamic filtering and adding additional entities to the curent selection.".
For more info, please read the SelectionEvent section in http://fusion360.autodesk.com/learning/learning.html?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051.
Jack
nnikbin
Hi liujac,
Thanks for your answer. This is exactly what I was looking for 🙂
Navid
