Bugs in controls.addSeparator method (ToolbarPanel object)
JeromeBriot
Mentor Mentor
JeromeBriot
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        panel = ui.allToolbarPanels.itemById('SolidCreatePanel')
        separator_one = panel.controls.addSeparator('a_unique_id', 'PrimitivePipe', True)
        print(separator_one.id)
        separator_two = panel.controls.addSeparator('another_unique_id', 'PrimitivePipe', False)
        print(separator_two.id)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The code should add two separators next to the "Pipe" entry under the "Create" menu, but fails on two points.
1) The second separator is not created because there is already another separator below the "Pipe" entry.
2) The specified ids are not set correctly as the print statement returns (for example) 5d2cae42-c725-4269-b82e-b60c31d4ba50 and 83f39f92-0ef6-4afb-999a-2f9369402684 instead of 'a_unique_id' and 'another_unique_id'
ekinsb
Thanks for reporting this.  I am able to reproduce the problem with the ID and have logged a bug.  However, for the other problem of it not being created because there's already one there, it is being created but apparently if there's nothing in between them, separators display on top of each other.  So there are actually two there but you just can't tell.
Brian Ekins
Mod the Machine blog
