[Bug] intersectWithSketchPlane method doesn't create closed profiles
JeromeBriot
Mentor Mentor
JeromeBriot
I wrote a code that slices a body using the intersectWithSketchPlane method to get sketch profiles.
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Slice spacing in cm
        sliceSpacing = 0.2
        body = ui.selectEntity('Select a body', 'SolidBodies').entity
        if body is None:
            return
        rootComponent = body.parentComponent.parentDesign.rootComponent
        bbPointMax = body.boundingBox.maxPoint
        bbPointMin = body.boundingBox.minPoint
        baseFeats = rootComponent.features.baseFeatures
        baseFeat = baseFeats.add()
        baseFeat.startEdit()
        planes = rootComponent.constructionPlanes
        planeInput = planes.createInput()
        planeInput.targetBaseOrFormFeature = baseFeat
        numSlices = math.floor((bbPointMax.z - bbPointMin.z) / sliceSpacing)
        offset = adsk.core.ValueInput.createByReal(bbPointMin.z)
        planeInput.setByOffset(rootComponent.xYConstructionPlane, offset)
        plane = planes.add(planeInput)
        sketches = rootComponent.sketches
        msg = ''
        for i in range(0, numSlices+1):
            vector = adsk.core.Vector3D.create(0.0, 0.0, bbPointMin.z + i * sliceSpacing)
            transform = adsk.core.Matrix3D.create()
            transform.translation = vector
            plane.transform = transform
            sketch = sketches.add(plane)
            sketch.intersectWithSketchPlane([body])
            sketch.name = 'MySketch_{:03d}'.format(i)
            sketch.isVisible = False
            if sketch.profiles.count == 0:
                sketch.isVisible = True
                msg += 'MySketch_{:03d} : no profile\n'.format(i)
        baseFeat.finishEdit()
        if msg:
            ui.messageBox(msg)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
It works well except on some geometries like the one attached to this message.
Some intersections don't create closed profiles (forget about the first and the last ones):
MySketch_000 : no profile
MySketch_011 : no profile
MySketch_012 : no profile
MySketch_013 : no profile
MySketch_014 : no profile
MySketch_037 : no profile
MySketch_038 : no profile
MySketch_049 : no profile
Any ideas?
Thank you.
MichaelT_123
Hi Mr Jérôme Briot,
... yep ... it is a miracle. It is always good to scrutinize such events to avoid fake ones (given time and level of devotion), so I did.
I took a few body/sketch intersections. Those close to the origin's XY plane were OK.
However, when I moved the offset plane (sketch) to distance -22.0, things became interesting.
The expected intersection profile has not come up (in an active&broken intersection link).
Following the sketch with the broken intersection link, I have found "suspicious free points" at the bottom slopes of the body and removing them one by one, I discovered ... devilish one! ... hence by removing it ... the peace was restored.
The question is ... WHY?
My subjective telepathic whispers induced that there is something suspicious in the bottom slope surface's construction and its successive topological behaviour. Unfortunately, I can't penetrate deeper into the intricacy of the underlying intersection algorithm, so I will cast my trust on TF360 to do so 😎.
With Regards
MichaelT
MichaelT
JeromeBriot
Thank you @MichaelT_123
I keep investigating this issue further on my side.
BrianEkins
Do you get the same results when you do the intersection interactively and not using the API?  I would assume so which indicates it's a general problem with the intersect code and nothing that's specific to the API.  In that case, it's probably best to report it in the Fusion 360 Support forum and don't mention anything about the API in your description.
Brian Ekins
MichaelT_123
Hi Mr Jérôme Briot,
I agree,… Mr Ekins explanation is spot on … as at the end, ConstructionPlane is anchored in the model space by Plane3D object, which in term is defined by the rotation matrix + translation (4x4 matrix).
Regarding the "offsetting planes", please find included my sample. I have used planeInput.setByPlane(plane3D) where the ConstructionPlane is derived directly from plane3D (as per above). The method can only be implemented in DirectMode; however, it offers much greater flexibility (and simplicity) by giving access to every element of the rotation matrix and allowing complete control of positioning the plane in 3Dspace.
#Author-MT_123
#Description-Test_PlaneOffset
import adsk.core, adsk.fusion, traceback
def run(context):
    try:
        design = adsk.fusion.Design.cast(app.activeProduct)
        root   = design.rootComponent
        origin = adsk.core.Point3D.create( 0.0, 0.0,  0.0)
        baseFeats = root.features.baseFeatures
        planes     = root.constructionPlanes
        for direction in [ 'x', 'y','z']:
            for off in [0, 2, 4, 6]:
                if   direction == 'x':
                    vector  = adsk.core.Vector3D.create( off, 0.0, 0.0)
                    normal  = adsk.core.Vector3D.create( 1.0, 0.0, 0.0)
                elif direction == 'y':
                    vector = adsk.core.Vector3D.create( 0.0, off, 0.0)
                    normal = adsk.core.Vector3D.create( 0.0, 1.0, 0.0)
                elif direction == 'z':
                    vector = adsk.core.Vector3D.create( 0.0, 0.0, off)
                    normal = adsk.core.Vector3D.create( 0.0, 0.0, 1.0)
                plane3D = adsk.core.Plane.create(origin, normal)
                transform = plane.transform
                plane.name = 'dir_' + direction + '_' + str(off)
    except:
        if ui:
With Regards
MichaelT
MichaelT
