Best way to query API objects?
bmyers1
bmyers1
I am brand new to Fusion's API and I was wondering if Fusion has developer tools or an easy way to view information about different objects I am looking to manipulate in the API.
Jorge_Jaramillo
I don't know any development tool.
I often use the Text Command window to display information about the model in two ways:
- From the scripts: using the Application.log() function
- From the same text command window: first choose "Py" in the lower right corner and then write any Python sentence which it evaluates immediately as you can see in the next image:
I hope this can help.
Jorge Jaramillo
bmyers1
@Jorge_Jaramillo Thank you I will try that
JeromeBriot
@bmyers1  I'm not sure exactly what you're looking for but you can try Fusion360DevTools by @prainsberry
=> https://github.com/AutodeskFusion360/Fusion360DevTools
You can use the GitHubToFusion to install the add-in: https://apps.autodesk.com/FUSION/en/Detail/Index?id=789800822168335025&os=Win64&appLang=en
bmyers1
@JeromeBriot That's Exactly what I wanted!  Thank you!
