API - MILLTURN setup - will not return a fixture / MILL setup does it.
martini_ewald
Message 1 of 1
martini_ewald
Ciao all,
please see the script - the MILLTURN setup retur allway 0 fixture / MILL setup return 1 fixture. Why? It seems to me to be an FUSION 360 Issue.
#Description - Script to demonstrate a missfunktion in FUSION360 #hasGlobalParameter("autodeskcam:fixture-path") FALSE on Post.CPS in a MillTurn SETUP.
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        root: fusion.Component = rootOcc.component
        #generate Mill setup
        setup: cam.Setup = create_setup(
            camObj,
            root.bRepBodies[0],
            root.allOccurrences[0],
            "MILL"
        setup.fixtureEnabled = True
        ui.messageBox('Setup ' + setup.name + ' has ' + str(setup.models.count) + ' models and ' + str(setup.fixtures.count) + ' fixtures', "MILL Setup")
        #generate MillTurn setup
            camObj,
            root.bRepBodies[0],
            "MILLTURN"
        ui.messageBox('Setup ' + setup.name + ' has ' + str(setup.models.count) + ' models and ' + str(setup.fixtures.count) + ' fixtures', "MILLTURN Setup")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_setup(
    camObj: cam.CAM,
    targetBody: fusion.BRepBody,
    fixture: core.Base,
    strOpType,
    ) -> cam.Setup:
    setups: cam.Setups = camObj.setups
    match strOpType:
        case "MILL":
            setupIpt: cam.SetupInput = setups.createInput(
            cam.OperationTypes.MillingOperation
            setupIpt.name = strOpType
        case "MILLTURN":
            cam.OperationTypes.TurningOperation
    setupIpt.models = [targetBody]
    setupIpt.fixtures = [fixture]
    setup: cam.Setup = setups.add(setupIpt)
    return setup
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
Replies (0)
