Message 1 of 1
API - MILLTURN setup - will not return a fixture / MILL setup does it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ciao all,
please see the script - the MILLTURN setup retur allway 0 fixture / MILL setup return 1 fixture. Why? It seems to me to be an FUSION 360 Issue.
#Description - Script to demonstrate a missfunktion in FUSION360 #hasGlobalParameter("autodeskcam:fixture-path") FALSE on Post.CPS in a MillTurn SETUP.
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
ui: core.UserInterface = None
try:
app: core.Application = core.Application.get()
ui = app.userInterface
camObj: cam.CAM = get_cam_product()
rootOcc: fusion.Occurrence = camObj.designRootOccurrence
root: fusion.Component = rootOcc.component
#generate Mill setup
setup: cam.Setup = create_setup(
camObj,
root.bRepBodies[0],
root.allOccurrences[0],
"MILL"
setup.fixtureEnabled = True
ui.messageBox('Setup ' + setup.name + ' has ' + str(setup.models.count) + ' models and ' + str(setup.fixtures.count) + ' fixtures', "MILL Setup")
#generate MillTurn setup
camObj,
root.bRepBodies[0],
"MILLTURN"
ui.messageBox('Setup ' + setup.name + ' has ' + str(setup.models.count) + ' models and ' + str(setup.fixtures.count) + ' fixtures', "MILLTURN Setup")
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def create_setup(
camObj: cam.CAM,
targetBody: fusion.BRepBody,
fixture: core.Base,
strOpType,
) -> cam.Setup:
setups: cam.Setups = camObj.setups
match strOpType:
case "MILL":
setupIpt: cam.SetupInput = setups.createInput(
cam.OperationTypes.MillingOperation
setupIpt.name = strOpType
case "MILLTURN":
cam.OperationTypes.TurningOperation
setupIpt.models = [targetBody]
setupIpt.fixtures = [fixture]
setup: cam.Setup = setups.add(setupIpt)
return setup
def get_cam_product() -> cam.CAM:
activete_cam_env()
return app.activeProduct
def activete_cam_env() -> None:
ui: core.UserInterface = app.userInterface
camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
camWS.activate()
