wrong syntax in Script
jean-michel_legoff
jean-michel_legoff
I'm trying my first script in Fusion.
To help me, I asked Chat GPT to write the script, but it looks that it miss something.
Here is what I want to do:
I have a design with some named Sketches.
for each of this sketch, I wnat to generate a new component with a extrusion ot this sketch.
And name the component with the name of the sketch.
could someone help me to correct this script?
#Author-
#Description-
import adsk.core, adsk.fusion, traceback
def run(context😞
    try:
        app = adsk.core.Application.get()
        ui = app.userInterface
        # Get the active design
        design = app.activeProduct
        # Get the root component of the active design
        root_comp = design.rootComponent
        # Get the sketches in the design
        sketches = root_comp.sketches
        # Iterate through each sketch
        for sketch in sketches:
            # Create a new component for each sketch
            new_comp = root_comp.occurrences.addNewComponent(adsk.core.Matrix3D.create())
            # Extrude the sketch
            extrudes = new_comp.component.features.extrudeFeatures
            ext_input = extrudes.createInput(sketch.profiles.item(0), adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
            distance = adsk.core.ValueInput.createByReal(5)
            ext_input.setDistanceExtent(False, distance)
            extrudes.add(ext_input)
            # Name the component with the sketch name
            new_comp.name = sketch.name
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @jean-michel_legoff -San.
Try fixing it as follows.
            # new_comp.name = sketch.name
            new_comp.component.name = sketch.name
jean-michel_legoff
Many Thanks...
That's it...
jean-michel_legoff
I want to modify my script a little.
After making the componenet, I want to copy the current sketch in this new componenet.
Iv' tried to add this line but it's not working:
can you see what's wrong?
Many Thanks
jean-michel_legoff
Hello @kandennti
have you any hint to help me moving the sketch in the component as well?
Many Thanks
kandennti
It is possible that I am not understanding what you mean.
You can move elements of a sketch by using the Sketch.move method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-908cc941-6522-4a24-94d5-90f98dce20fd
The following sample moves all the curves in the first sketch of the first component (occurrence) by 10mm.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        des: fusion.Design = app.activeProduct
        root: fusion.Component = des.rootComponent
        # get occurrence - component
        occ: fusion.Occurrence = root.occurrences[0]
        occComp: fusion.Component = occ.component
        # get sketch
        skt: fusion.Sketch = occComp.sketches[0]
        skt = skt.createForAssemblyContext(occ)
        # create move matrix
        mat: core.Matrix3D = core.Matrix3D.create()
        mat.translation = core.Vector3D.create(1,0,0)
        # move sketch curves
        skt.move(
            core.ObjectCollection.createWithArray(
                list(skt.sketchCurves)
            mat,
    except:
        if ui:
However, this may not be possible due to dimensional constraints, etc.
If you can attach more specific data, it will make it easier for us to answer, including others.
jean-michel_legoff
Sorry for the confusion,
By moving, I don't speak about geometric transformation...
I was saying moving in the construction tree and sliding the Sketch from Roo_Comopent to a new one.
But the answer is given in another thread by Copying Sketches entities from the root sketch to the component sketch.
Sorry for the annoyance.
