Where to install a Python module so a Python script can import it?
cadTPLWJ
Message 1 of 8
cadTPLWJ
In F360 running on Win10, I want to use "import svgwrite" in my script.
Where shall I "pip install " to for this to work?
I realise this has been asked a lot before, but I have not found anything that works for me yet.
Replies (7)
Message 2 of 8
Jorge_Jaramillo
In this topic https://forums.autodesk.com/t5/fusion-360-api-and-scripts/import-data-from-excel-type-xlsx/m-p/11249... on message #5 I gave a solution step-by-step to make it work.
Please take into account that Fusion 360 will include soon Python's version 3.10 and the procedure could change.
I hope this could help.
Jorge Jaramillo
Software Engineer
Message 3 of 8
cadTPLWJ
 @Jorge_Jaramillo
In the Text Command window in Fusion you will get something like this:
Please tel me, where will this text appear?
Message 4 of 8
Jorge_Jaramillo
Which text are you talking about?
Didn't get your question. Please explain it.
Message 5 of 8
cadTPLWJ
@Jorge_Jaramillo
You say -->  7. Finally run the script and check for the data in Text Commands window:
As an inexperienced user I can't find the "Text Commands window"
Message 6 of 8
Jorge_Jaramillo
Hi @cadTPLWJ ,
Under menu File > View > Hide/Show Text Commands you can hide/display the Text Command window which by default is located in Fusion's lower area:
Every app.log() call will print the output to this window.  I use it often to test my developments.
Jorge Jaramillo
Software Engineer
Message 7 of 8
cadTPLWJ
@Jorge_Jaramillo
app.log() is a nice debug tool, thanks!
Also got the pip install to work as described. Again, Thanks!
Message 8 of 8
Jorge_Jaramillo
It's nice it helped you out.
