what is the ID for the simulation workspace?
lsRDZZQ
lsRDZZQ
Hi, I want to add a button to the simulation workspace, can not find the id for that,
is it FusionModelingEnvironment? thanks
marshaltu
It should be 'SimulationEnvironment'. You could iterate all workspaces by the following codes:
#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        for workspace in ui.workspaces:
            ui.messageBox(workspace.id)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal
Marshal Tu
Fusion Developer
lsRDZZQ
Thanks, I tried it, now i can get the correct workspace object. but when i try to add a panel to Simulation workspace, it always return null. But the same code i can add a panel to solid workspace without any problems.
auto workspace = workspaces->itemById("SimulationEnviroment");
auto toolbarPanels = workspace->toolbarPanels();
auto panel = toolbarPanels->add("NewPanelID", "NewPanel");
auto panelCtrl = panel->controls();
If i change the id to "FusionSolidEnviroment", toolbarPanels.add can success without any problems. Please help me out. thanks
marshaltu
Please try to get workspaces by productType and then it should work.
This was our mistake how to design the API. One workspace might belong to multiple products and multiple workspaces might associate to one product. We need users' input which workspace of product they want to add toolbar item into. Unfortunately we cannot do cleanup for old design to keep backward compatibility.
We will do improvement to prompt users with meaningful message once users run into the kind of issue in future releases.
Marshal
auto workspaces = ui->workspacesByProductType("SimStudiesProductType");
Marshal Tu
Fusion Developer
david.lopez7E84R
What would this look like for PANEL_ID’s?
