Voronoi Sketch Generator Script
MarkusSchnabel1921
MarkusSchnabel1921
Hi to all,
the Voronoi script seems quite interesting. Today I thought of testing it, but it seems it is only possible to generate the pattern on square, did I miss something?
I tryed a spline to have sketch outline in which the pattern should live, but activating the script I always get the square.
Is there a chance to use it on a closed outline?
best regards
Markus
ekinsb
The current version of the add-in is limited to a rectangular area.  The workaround with the current version is to fill a rectangular pattern that is larger than the arbitrary area you want to fill and then manually delete the curves that fall outside the area and modify those that cross over so that they all lie within the area you want the pattern within.
Brian Ekins
Mod the Machine blog
MarkusSchnabel1921
Hi Brian,
thank you for the repley. The work ouround is of course feasable but the flow is lost. The idea to have a pattern being in relation with its surroundings is very attactive for the design point of view.
Looking forward for the upcoming development.
best regards
Markus
