Voronoi Sketch Generator Script
hanskellner
Autodesk Autodesk
Message 1 of 17
hanskellner
I've written and posted a script to generate Voronoi sketches.
Here's an example of a model I created by applying voronoi sketches to a cylinder body:
More information, JavaScript code, and how to install are located here:
https://github.com/hanskellner/Fusion360Voronoi
Cheers!
Hans Kellner
Senior Manager, Principal Engineer
Replies (16)
Message 2 of 17
prainsberry
Very cool!!
Patrick Rainsberry
Developer Advocate, Fusion 360
Message 3 of 17
rada.mar
indeed very cool!!
Message 4 of 17
cekuhnen
This is probably the most exciting thing I have seen in Fusion since the Timeline and surfacing commands being included.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 5 of 17
daniel_lyall
I cant get it to work with win 7
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 6 of 17
hanskellner
Hi Daniel -
Would you provide more information on what is failing?
You may also find more information by running the script in the script debugger and viewing the console output. If something is failing then a error message will be displayed in there.
Hans Kellner
Message 7 of 17
daniel_lyall
I put it in like you instructed to do it just does not work no error masages come up debugger has no problems it does not give any console out put it may need put in diffrently with windows I would realy like to use it
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 17
hanskellner
Ok, a few questions for you.
- Does the settings dialog appear?  Or nothing at all?
- Where did you install the script?  Which folder on your system?
Hans Kellner
Message 9 of 17
ekinsb
I don't believe it's a Win7 issue because that's what I have and it's working great.  We just need some more information about exactly what you're seeing and then we should be able to diagnose the problem.
Brian Ekins
Mod the Machine blog
Message 10 of 17
daniel_lyall
my fault did it wrong all working know sorry for being a nob lol
its cool
Daniel Lyall
The Big Boss
Mach3 User
Message 11 of 17
hanskellner
No worries!  Glad you got it working.
Btw - Here's a new model I created with the help of the script:
Voronoi Table
Hans Kellner
Message 12 of 17
daniel_lyall
that table is pretty cool just been playing it`s fun thanks for the addon
Daniel Lyall
The Big Boss
Mach3 User
Message 13 of 17
Vladimir.Ananyev
Really nice. Thanks a lot for this code!
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 14 of 17
LMD001
Hello hanskellner,
Thank you for this script!
Very nice.
Best regards,
Ludo
Message 15 of 17
Works marvelously.
My favorite new toy in Fusion360!
Thanks for a great piece of script!!
Message 16 of 17
jschmidt1340
I haven't been able to get this script to install. I have followed all available instructions. I have copied the contents of the folder to:
~/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts
I receive the error:
Any assistance is appreciated!
Message 17 of 17
hanskellner
I've verified that I'm able to install and run the Voronoi script on my Mac.
To clarify, did you extract the files into a new folder within the Scripts folder?  For example:
~/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts/Fusion360Voronoi
The error indicates the files might have been copied into the Scripts folder or into another folder that already contained another script.  Please verify that you have extracted the files into a new and empty folder.
Hans Kellner
