vector normal to face problem direction inside or outside of the body
daniele_spagli
daniele_spagli
Hi, I'm trying to extract a normal vector to a face that is constantly oriented with direction outside the body. If I don't understand wrong the data that I obtain from .normal is not consistent but depend if the face is generated by a tool (boolean operation) instead by normal operations on the face.
Someone know how to make this vector all the times pointing out or at least get a true/false variable that say to me if is oriented inside or outside?
def searchFaceAligned(bodies,vector):
    for body in bodies:
        facesModel=body.faces
        searchEdge=True
        rak=0
        rakMax=facesModel.count
        while searchEdge and rak<=rakMax:
            faceModel=[]
            faceModel=facesModel.item(rak)
            rak+=1
            facePlane=faceModel.geometry
            if facePlane.objectType=="adsk::core::Plane":
                faceNormal=facePlane.normal
                if vector.isParallelTo(faceNormal):
                    searchEdge=False
                    isrev=faceModel.isParamReversed
        angleZ=abs(vector.angleTo(faceNormal))
        if angleZ<1:
            if isrev:
                inverse=True
            else:
                inverse=False
        else:
            if isrev:
                inverse=False
            else:
                inverse=True
        return faceModel, inverse
daniele_spagli
It seems that is an easy solution, need only to add the line
faceNormal.normalize()
after the acquisition of the vector.
Daniele
BrianEkins
I think you still have a problem and just got lucky in your test because normalizing the vector shouldn't change anything. The vector you are getting should already be normalized. To ensure you get a normal pointing out of the face, you need to use the functionality on the SurfaceEvaluator object that you get from the BRepFace object. Here's a modified version of your code that does that. I didn't test it, so there might be a typo or two, but it illustrates the idea.
def searchFaceAligned(bodies, vector):
    for body in bodies:
        searchEdge=True
        rak=0
            faceModel=[]
            rak+=1
            eval = faceModel.evaluator
            (_, faceNormal) = eval.getNormalAtPoint(faceModel.pointOnFace)
        return faceModel, faceNormal
Brian Ekins
daniele_spagli
Yes, I guess this was the thing.
I already made the surface evaluator and add normalize the vector. It worked well so I thought it was because the normalize function but later I delete the surface evaluator and it stop to work consistently again.
So maybe my memory worked bad when I thought to still have problems with the surface evaluator.
I will try again and I will confirm it.
thanks
Daniele
daniele_spagli
Thank you alot Brian, you save my sunday. 🙂
I notice that you changed the return function, but this is not what I need: I want to set the checkbox or not in the set new Z for the tool in the CAM section. I have a cnc with side drills and setting manually the Z for it was quite annoying. But don't worry, I keep only the 2 lines that I needed and it works like a charm. 🙂
