ValidateInputs does not validate...
Le_Bear
Message 1 of 10
Le_Bear
Slowly progressing toward my first addin creation.
for now I have a single commandInputs, to select a sketchLine, and this is working as expected. But I want this selected line to be a construction line, so I am attempting to check if this is he case inside a ValidateInputs event, but does not seem to work, meaning a regular line is OK too...
Here is the code involved:
# Event handler for the commandCreated event.
class onCommandCreatedEventHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        # Verify that a sketch is active.
        app = adsk.core.Application.get()
        if app.activeEditObject.objectType != adsk.fusion.Sketch.classType():
            ui = app.userInterface
            ui.messageBox('A sketch must be active for this command.')
            return False
        eventArgs = adsk.core.CommandCreatedEventArgs.cast(args)
        #Get the command
        cmd = eventArgs.command
        # Get the CommandInputs collection associated with the command.
        inputs = cmd.commandInputs
        constructionLine = inputs.addSelectionInput('constructionLineUniqueID','Select a Construction Line', 'The line you select will be the Chord of your Airfoil' )
        constructionLine.addSelectionFilter('SketchLines')
        # Connect to the execute event.
        onExecute = SampleCommandExecuteHandler()
        cmd.execute.add(onExecute)
        handlers.append(onExecute)
#        #Connect to the ValidateInputs Event
        onValidate = SampleCommandValidateInputsHandler()
        cmd.validateInputs.add(onValidate)
        handlers.append(onValidate)
class SampleCommandValidateInputsHandler(adsk.core.ValidateInputsEventHandler):
    def __init__(self):
        super().__init__()
        eventArgs = adsk.core.ValidateInputsEventArgs.cast(args)
        inputs = eventArgs.firingEvent.sender.commandInputs
        selLine = inputs.itemById('constructionLineUniqueID')
        if selLine.objectType == adsk.fusion.SketchLine.classType():
            myLine = adsk.fusion.SketchLine.cast(selLine)
        if myLine.isConstruction:
            eventArgs.areInputsValid = True
            return
        else:
            eventArgs.areInputsValid = False
            return
Checking with the debugger, I can see the objectType for selLine is NOT sketchLine....Guess I have to find the way to make it so?
Bernard Grosperrin
Autodesk Certified Instructor
FaceBook Group | Forum | YouTube
Group Network Leader
Accepted solutions (3)
Replies (9)
Message 2 of 10
Le_Bear
I found a solution myself, which is working well, but I have other questions....
Here is the working ValidateInputHandler
    def __init__(self):
        super().__init__()
        selLineInput = adsk.core.SelectionCommandInput.cast(inputs.itemById('constructionLineUniqueID'))
        myLine = adsk.fusion.SketchLine.cast(selLineInput.selection(0).entity)
            return
        else:
            return
Bernard Grosperrin
Message 3 of 10
Le_Bear
Now, the question is:
How can I let the user know that the OK button is disabled because he did not select a construction line? I believe it would be nice to let the user know why his selection does not pass the validation test.
Thanks for any help!
Bernard
Bernard Grosperrin
Message 4 of 10
marshaltu
One sample you would be able to refer to is "Spur Gear". It shows prompt message at the bottom of dialog when users give invalid inputs.
Marshal
Marshal Tu
Fusion Developer
Message 5 of 10
BrianEkins
What you want to use in this case is the selectionEvent of the Command object.  For the selection input you can only filter using types of objects, but using the selectionEvent you can use any criteria you want for what the user can select.  As the user is moving the mouse over the model to select something the selectionEvent is fired before it is highlighted to the user and you can look at what the mouse is currently over and choose whether it should be made selectable or not.
Brian Ekins
Message 6 of 10
Le_Bear
That's an idea, I will like how this is done. Thanks!
Bernard Grosperrin
Message 7 of 10
Le_Bear
I did try the selectionEvent, but it was not working for me, maybe I had bug. It would be the best if it worked. I will experiment with it again. Thanks!
Bernard Grosperrin
Message 8 of 10
Le_Bear
I did use a textBox with an HTML formated text, works well. Thanks, did not thought I could use it this way.
Bernard Grosperrin
Message 9 of 10
BrianEkins
Here's a variation of your code that uses the selection input event to limit the selection to construction lines.  I think it's best to try and control the selection to get it correct the first time rather than let them select anything and then report the problems.
    def __init__(self):
        super().__init__()
        if _app.activeEditObject.objectType != adsk.fusion.Sketch.classType():
            _ui.messageBox('A sketch must be active for this command.')
            return False
        #Get the command
        _handlers.append(onExecute)
        # Connect to the Selection event.
        onSelectionEvent = SampleCommandSelectionEventHandler()
        cmd.selectionEvent.add(onSelectionEvent)
        _handlers.append(onSelectionEvent)
# Event handler for the selectionEvent event.
class SampleCommandSelectionEventHandler(adsk.core.SelectionEventHandler):
    def __init__(self):
        super().__init__()
        try:
            eventArgs = adsk.core.SelectionEventArgs.cast(args)
            skLine = adsk.fusion.SketchLine.cast(eventArgs.selection.entity)
            if skLine.isConstruction:
                eventArgs.isSelectable = True
            else:
                eventArgs.isSelectable = False
        except:
            if _ui:
                _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Message 10 of 10
Le_Bear
Thanks Brian, not sure what I did wrong when I tried the first time, but tis works perfectly!
Bernard Grosperrin
