- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Let's assume I created a Fusion 360 component that represents a small board computer. The component represents the PCB outline and an arbitrary number of mounting holes. Let's assume I'm creating a new component, which means a tray on which the PCB needs to be mounted. To add spacers/standoffs to the tray, I need to have corresponding points or holes that match the PCB. For this example, the PCB will have four holes.
When looking at the holeFeatures of the top face of the PCB, only one is returned instead of 4. I'm assuming this may be because there are four occurrences of the same feature. If that's the case, I can't figure out how to get the other holes.
I was able to create a self-contained script to reproduce the issue.
# Author-
# Description-
import adsk.core, adsk.fusion, adsk.cam, traceback, math, time
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
doc = setup(app)
design = doc.products[0]
components = design.allComponents
tray = components.itemByName('Tray')
component = components.itemByName('Component')
move_component(component, 2, 2, 0.16)
face = get_top_face(tray)
device_holes = component.features.holeFeatures
sketch = tray.sketches.addWithoutEdges(face)
sketch.name = 'Standoffs'
offset_sketch_points = sketch.sketchPoints
distance = adsk.core.ValueInput.createByString("1.52 mm")
fastener_diameter = adsk.core.ValueInput.createByString('4 mm')
points = adsk.core.ObjectCollection.create()
for h in device_holes:
px = h.position.x + 2
py = h.position.y + 2
pt = offset_sketch_points.add(adsk.core.Point3D.create(px, py, 0))
points.add(pt)
holes = tray.features.holeFeatures
hole = holes.createSimpleInput(fastener_diameter) # TODO Fix
hole.setPositionBySketchPoints(points)
hole.setDistanceExtent(distance)
hole = holes.add(hole)
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def get_top_face(component):
body: adsk.fusion.BRepBody = component.bRepBodies[0]
faces: adsk.fusion.BRepFaces = body.faces
return max(faces, key=(lambda f: f.centroid.z))
def move_component(item, x, y, z):
objects = adsk.core.ObjectCollection.create()
objects.add(item.bRepBodies.item(0))
vector = adsk.core.Vector3D.create(x, y, z)
transform = adsk.core.Matrix3D.create()
transform.translation = vector
features = item.features.moveFeatures
feature = features.createInput(objects, transform)
features.add(feature)
def setup(app):
lib = app.materialLibraries.itemByName('Fusion 360 Material Library')
pcb = lib.materials.itemByName('FR4')
steel = lib.materials.itemByName('Steel')
doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
units_mgr = design.unitsManager
units_mgr.distanceDisplayUnits = adsk.fusion.DistanceUnits.MillimeterDistanceUnits
root = design.rootComponent
setup_component(root, 'Component', 6, 8, 1, pcb)
setup_tray(root, 17, 17, 2, 4, 6, steel)
# doc.saveAs("Align Test", folder, '', '')
return doc
def setup_tray(parent, width, depth, edge, space_width, space_depth, material):
occurrences = parent.occurrences
component = occurrences.addNewComponent(adsk.core.Matrix3D.create()).component
component.name = "Tray"
component.material = material
sketch = component.sketches.add(component.xYConstructionPlane)
sketch.name = component.name
lines = sketch.sketchCurves.sketchLines
p1 = adsk.core.Point3D.create(0, 0, 0)
p2 = adsk.core.Point3D.create(width, depth, 0)
rectangle = lines.addTwoPointRectangle(p1, p2)
sketch.geometricConstraints.addHorizontal(rectangle.item(0))
sketch.geometricConstraints.addHorizontal(rectangle.item(2))
sketch.geometricConstraints.addVertical(rectangle.item(1))
sketch.geometricConstraints.addVertical(rectangle.item(3))
sketch.sketchDimensions.addDistanceDimension(rectangle.item(0).startSketchPoint,
rectangle.item(0).endSketchPoint,
adsk.fusion.DimensionOrientations.HorizontalDimensionOrientation,
adsk.core.Point3D.create(width / 2, -1))
sketch.sketchDimensions.addDistanceDimension(rectangle.item(3).startSketchPoint,
rectangle.item(3).endSketchPoint,
adsk.fusion.DimensionOrientations.VerticalDimensionOrientation,
adsk.core.Point3D.create(-1, depth / 2))
extrudes = component.features.extrudeFeatures
prof = sketch.profiles.item(0)
distance = adsk.core.ValueInput.createByString("1.66 mm")
extrude = extrudes.addSimple(prof, distance, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
body = extrude.bodies.item(0)
body.name = sketch.name
def setup_component(parent, name, width, depth, edge, material):
component.name = name
distance = adsk.core.ValueInput.createByString("1.6 mm")
face = body.faces.item(4) # Top Face
sketch = component.sketches.addWithoutEdges(face)
sketch.name = 'Mounting'
point1 = offset_sketch_points.add(adsk.core.Point3D.create(edge, edge, 0))
point2 = offset_sketch_points.add(adsk.core.Point3D.create(edge, depth - edge, 0))
point3 = offset_sketch_points.add(adsk.core.Point3D.create(width - edge, edge, 0))
point4 = offset_sketch_points.add(adsk.core.Point3D.create(width - edge, depth - edge, 0))
points.add(point1)
points.add(point2)
points.add(point3)
points.add(point4)
fastener_diameter = '3 mm'
hole = holes.createSimpleInput(adsk.core.ValueInput.createByString(fastener_diameter))
And like my actual code, this only creates one hole, which is not sufficient to mount expensive electronics.
How does one get the positions of the other holes? Ignore the setup method; it's just there to aid with the components.
https://wernerstrydom.com
