Using Cloud Library Post for Post Process Input
Joshua.mursic
Joshua.mursic
Hello, I am trying to use a Post processor on my cloud library for use in the PostProcessInput class. The
PostProcessInput class wants the post configuration to be a string path to the post, but I dont understand how to give it a post that is located in my Cloud Library.
import adsk.core, adsk.cam
app = adsk.core.Application.get()
ui = app.userInterface
def getPost(targetPostName:str):
    camManager = adsk.cam.CAMManager.get()
    libraryManager = camManager.libraryManager
    postLibraries = libraryManager.postLibrary
    cloudFolder = postLibraries.urlByLocation(adsk.cam.LibraryLocations.CloudLibraryLocation)
    cloudPostlibrary = postLibraries.childAssetURLs(cloudFolder)
    # Get Templates
    for cloudPost in cloudPostlibrary:
        postName = cloudPost.toString()
        if targetPostName in postName:
            postUrl = adsk.core.URL.create(postName)
            # postConfiguration = postLibraries.postConfigurationAtURL(postUrl)
            return postUrl.toString()
    # Error if not found
    ui.messageBox(f"Could not find Postprocessor {targetPostName}")
def postProcess():
    cam:adsk.cam.CAM = app.activeDocument.products.itemByProductType("CAMProductType")
    setups = cam.setups
    setup = setups.item(0)
    # specify the program name, post configuration to use and a folder destination for the nc file
    programName = '1010'
    postConfig = getPost("Dumper.cps")
    outputFolder = cam.temporaryFolder
    units = adsk.cam.PostOutputUnitOptions.DocumentUnitsOutput
    # create the postInput object
    postInput = adsk.cam.PostProcessInput.create(programName, postConfig, outputFolder, units)
    postInput.isOpenInEditor = False
    cam.postProcess(setup, postInput)
Here I am searching my cloud library for the post with the name Dumper.cps, then I am getting the URL to that post as a string, which looks like this: "cloud://Dumper.cps"
I pass that to the PostProcessInput class, but it is returning:
"RuntimeError: 3 : The input configuration file does not exist."
Is it possible to use cloud posts?
kandennti
Hi @Joshua.mursic -San.
I modified it based on the sample here.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-995d634e-a8ef-4f2b-a826-1d32171f4998
    # Get Templates
            # return postUrl.toString()
            return postLibraries.postConfigurationAtURL(postUrl)
def postProcess():
    setups = cam.setups
    # units = adsk.cam.PostOutputUnitOptions.DocumentUnitsOutput
    # postInput = adsk.cam.PostProcessInput.create(programName, postConfig, outputFolder, units)
    # postInput.isOpenInEditor = False
    # cam.postProcess(setup, postInput)
    ncInput = cam.ncPrograms.createInput()
    ncInput.displayName = 'NC Program Sample'
    ncParameters = ncInput.parameters
    ncParameters.itemByName('nc_program_name').value.value = programName
    ncParameters.itemByName('nc_program_filename').value.value = 'NCProgramSample'
    ncParameters.itemByName('nc_program_openInEditor').value.value = False
    ncParameters.itemByName("nc_program_unit").value.value = 'DocumentUnit'
    ncParameters.itemByName('nc_program_output_folder').value.value = outputFolder
    ncInput.operations = list(setup.operations)
    newProgram = cam.ncPrograms.add(ncInput)
    newProgram.postConfiguration = postConfig
    postOptions = adsk.cam.NCProgramPostProcessOptions.create()
    newProgram.postProcess(postOptions)
It seems to work fine in my environment.
Joshua.mursic
@kandennti  thank you very much!
