Using a TemporaryBRepManager.copy in a combine operation fails
florian.pommereningDGUYA
In a script want to use a temporary BRepBody for cutting. This works fine if the temporary body was created with something like createCylinderOrCone but fails when the body is created with the copy function of TemporaryBRepManager. For some reason the base feature adding the temporary object to the document contains no bodies in case of using the copy, Although the copied body shows up in the document afterwards.
The following script shows the problem. If I comment in line 37, the script breaks.
import adsk.core, adsk.fusion, adsk.cam, traceback
import math
def createCylinder(x, y, r, h):
    app = adsk.core.Application.get()
    des = adsk.fusion.Design.cast(app.activeProduct)
    root = des.rootComponent
    sk = root.sketches.add(root.xYConstructionPlane)
    circs = sk.sketchCurves.sketchCircles
    circs.addByCenterRadius(adsk.core.Point3D.create(x,y,0), r)
    prof = sk.profiles.item(0)
    ext = root.features.extrudeFeatures.addSimple(
        prof, adsk.core.ValueInput.createByReal(h),
        adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
    return ext.bodies.item(0)
def run(context):
    ui = None
    try:
        ui  = app.userInterface
        c1 = createCylinder(0, 0, 2, 5)
        c2 = createCylinder(1, 1, 2, 3)
        c2.isLightBulbOn = False
        tempBRep = adsk.fusion.TemporaryBRepManager.get()
        # Works
        tempToolBody = tempBRep.createCylinderOrCone(
            adsk.core.Point3D.create(1, 1, 0), 2,
            adsk.core.Point3D.create(1, 1, 3), 2)
        # Fails with "RuntimeError: 3 : Bad index parameter" in the line below that uses baseFeat.bodies.item(0)
#        tempToolBody = tempBRep.copy(c2)
        baseFeat = root.features.baseFeatures.add()
        baseFeat.startEdit()
        toolBody = root.bRepBodies.add(tempToolBody, baseFeat)
        baseFeat.finishEdit()
        toolBodies = adsk.core.ObjectCollection.create()
        toolBodies.add(baseFeat.bodies.item(0))
        combineInput = root.features.combineFeatures.createInput(c1, toolBodies)
        combineInput.operation = adsk.fusion.FeatureOperations.CutFeatureOperation
        root.features.combineFeatures.add(combineInput)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
kandennti
Hi @florian.pommereningDGUYA .
I also tried.
No error occurred in direct mode.
In parametric mode, no error occurred if tempBRep.booleanOperation.
def run(context):
    ui = None
    try:
        # c2.isLightBulbOn = False
        # Works
        clone_c1 = tempBRep.copy(c1)
        cutOpe = adsk.fusion.BooleanTypes.DifferenceBooleanType
        tempBRep.booleanOperation(clone_c1, tempToolBody, cutOpe)
        root.bRepBodies.add(clone_c1, baseFeat)
    except:
        if ui:
I feel that BRepBody created by tempBRep.copy can only be used in direct mode or while editing the base future.
BrianEkins
I looked at this and can reproduce the problem.  There's a problem if the temporary B-Rep body is a copy of a parametric body then the base feature isn't correctly returning the body that's created in it.  This is a bug.  It should behave the same for a copied body or a newly created body.
Brian Ekins
Thanks. I worked around the problem in a similar way, keeping the copied body temporary until the end of the operation. This works for me but in general is only side-stepping the issue.
Thanks for the confirmation. Is there an issue tracker where I should report this as a bug?
kandennti
