Use a Fusion 360 Python script to use "SaveAs" to save a part to a specific folder
isocam
isocam
Support,
Can anybody update the following script to allow me to use "SaveAs" to save a part to a specific folder?
import adsk.core, adsk.fusion, traceback
def run(context):
ui = adsk.core.UserInterface.cast(None)
try:
app :adsk.fusion.Application = adsk.core.Application.get()
ui = app.userInterface
doc :adsk.core.Document = app.activeDocument
dataProject :adsk.core.DataProject = app.data.dataProjects[0]
rootFolder :adsk.core.DataFolder = dataProject.rootFolder
PartFileName = "TEST-FILE"
doc.saveAs(PartFileName, rootFolder, '', '')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
I NEED TO USE SAVEAS TO SAVE A "TEST-FILE" TO THE FOLDER
Project Files > Projects > 1070 - Drive Shaft
I want, for test purposes, to use SaveAs to save a part to a folder called:
"Project Files" > "Projects" > "1070 - Drive Shaft"
Please see the attached picture.
Many thanks in advance!!
Darren
HughesTooling
Sorry about previous answer, didn't realise you want to save to your hub.
You need to look at Component, not Document for this.
See this page in the help for SaveCopyAs from a component.
Mark
Mark Hughes
Owner, Hughes Tooling
isocam
I need to only save "f3d" files only.
Many thanks!
Darren
HughesTooling
@isocam  I edited my previous answer. I didn't realise you wanted to save to your hub and not your local file system.
Mark
Mark Hughes
BrianEkins
I was confused at first about what you're trying to do because your picture is a little confusing because of the names you've used for folders.  I believe you have a project named "Project Files" and then a folder within that project named "Projects" and it contains several folders including "1070 - Drive Shaft".  Assuming that's true and I haven't misunderstood what I saw, here's a little script that will the current document into the "1070 - Drive Shaft" folder, and the new file will be named "Test Part".  There's no error handling in case the project or a folder isn't found.  Because I don't have the same structure set up in my hub I wasn't able to test it but I believe it should work.
def saveAsFile(context):
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        data = app.data
        activeHub = data.activeHub
        # Get the project named "Project Files".
        proj: adsk.core.DataProject
        projFilesProject: adsk.core.DataProject = None
        for proj in activeHub.dataProjects:
            if proj.name == 'Project Files':
                projFilesProject = proj
                break
        # Get the folder named "Projects".
        projFolder = projFilesProject.rootFolder.dataFolders.itemByName('Projects')
        # Get the subfolder named "1070 - Drive Shaft".
        folder1070 = projFolder.dataFolders.itemByName('1070 - Drive Shaft')
        # Save As the active document.
        app.activeDocument.saveAs('Test Part', folder1070, 'Description', 'Tag')
    except:
        if ui:
Brian Ekins
